Results 1 to 10 of 17
Thread: Help - Coolant change on 4mo
    Wollongong, NSW
    Hey all,
    Went to change the coolant on my bora 4mo today but couldnt locate the drain point on the bottom of the radiator. Only thing i could thing to do was disconnect the hose as below and itd all drain from there?
    Is there something im not seeing or is that the way to do it? Sorry for the noob question im only used to working on jap cars.
    Cheers Curtis.
    Aug 2009
    Probably different on a 1.8t but I did exactly as you - took the bottom hose out. It's a bitch to get on and off and messy but it got the job done.
    Good luck. Remember to only use the vw g12+ coolant too!
    Platinum Grey mkV Jetta turbo, Viezu motorsport map, GT-CX 18", lowering to come
    Wollongong, NSW
    Ok thanks buddy, yeah the only reason why i didnt do it straight away was to try and avoid the mess. Do you remember approx how much coolant the system holds. Be about 4 litres wouldnt it?
    Jun 2011
    O'Connor, ACT / Balmain, NSW
    my coolant alarm went off this morning.
    1. Where can I get G12 coolant (canberra area) ? WOuld repco or kmart have this stuff
    2. How do you disconnect the coolant hose to let it drain ? Do you need any special tools etc
    cheers
    '01 Saab 9-3 S
    past rides: '01 Bora 4motion, '03 Golf Sport 2slow, '92 Ford Laser GL wagon (caught on fire)
    Jun 2011
    and 3. How much coolant do I need if i'm doing a full top-up
    '01 Saab 9-3 S
    Jul 2010
    Canberra , ACT
    Quote Originally Posted by curtis715 View Post
    im afraid you will have to go the hose way for drainage ..
    theres 2 variants.. some need a 9.4 Liters and some need 12 Liters .. best thing is to buy 5L bottle of 100% concentrated Red coolant ..
    i use Nulon .. it covers the needed requirements from VW .. and is about 30 bucks from stores like Autobarn and Autopro .. 5 Liter bottle will make up to 10 Liters of coolant ..
    VW BORA 2003 V6 4Motion
    Volkswagen Golf MK3 1997 CL 1.8L
    Rammstien + Autobahn + Volkswagen = Leben !
    Jul 2010
    Canberra , ACT
    Quote Originally Posted by governor22 View Post
    for the GTI you need 8 Liters of coolant .. i havent personally looked at the change in them .. however my money will be on the hose as well .. according to Nulon's guide .. the red stuff will cover you as well ..
    sam
    Jun 2011
    yeah, topped it up today... would've flushed it but they don't recommend you lift the car with only one jack .... i also couldn't get the front bumper off.... fail
    '01 Saab 9-3 S
    There's a drain tap on the bottom of the radiator on the passenger side.
    Without having a bone dry engine/radiator, I don't reckon I have ever put more that 4-5 litres in a VW.
    Jan 2009
    blankedy
    Are you sure the Nulon is a suitable spec? I can't find anything about it being G12+ compliant (the only VW coolant spec I know).
