Results 1 to 8 of 8
Thread: Help.. 1.6lt golf is using way too much fuel..
    Oct 2010
    Mildura, Victoria
    Hi all..
    My golf blows heaps of black smoke in the morning when its cold but also is using about 1/4 of a tank to do barely a 100kms... Can anyone help????
    '01 Mk4 Golf GL, Engine swapped to 1.8L GTi motor, Whiteline Swaybars, Nolathane & Pedders Bushes, K&N Oversize Pod Filter, 2 1/2 inch Cat back exhaust
    Mar 2011
    Dandenong, VIC
    hrmm this is weirdd ..give a quick check to your afm and make shore its plugged in and clean whilst your at it give a quick check to see that all the sparks are firing nicely and not over/underfueling chared black/white isnt a good sign hope this helps a bit
    can u supply any more information like what was last done to the car in mods or so ? if the engine bay was washed or whatever might be able to get a better idea :]
    edit :
    forgot to say with the afm just incase you dident know you cant wash it with normal chemicals/petrol so on i think the specialised spray was like $15-20 from a auto parts store lol had a freind wash he's with petrol and stuff it up XD
    -2003 Vw Bora Vr6 4-Motion - Back From The Dead LiNk tO PhOtO Thread
    -1993 Nissan Nx-R , SR20DE+T Project.
    -1993 Kawasaki ZZR250 (grey import)"The StreetFighter"
    Jul 2011
    Sounds like you need an oxygen sensor get it scanned and Checked.
    Dec 2008
    Northern Suburbs
    1.6 golfs hardly give trouble with air flow meters, and oxygen sensor doesnt work when the motor is cold so i would say its more than likely a coolant temp probe
    feel sluggish? temp gauge down?
    Aug 2007
    Quote Originally Posted by PeDiES View Post
    Black smoke in the morning could be but would have it scanned, SAI pump or dislodged pipe to it common, therefore the super rich cold strt mix doesnt get its blast of Secondary air from the pump on start up, even sticky combi valve, seen that too. Just watch you dont get carried away by thinking the o2 sensor doesnt work cold, maybe doesnt on this engine but systems go into closed loop sooner than you think.
    Drinking fuel could be a broken thermostat staying wide open, therefore the coolant temp sensor is doing its job right, so when its doin the job right and the stat is open , core temps are low and the injection pulse is wider, thus more fuel
    Jmac
    Alba European
    Oct 2010
    Mildura, Victoria
    Thanks everyone..
    Had it scanned at the performance shop here.. It's in bad shape lol both it's oxygen sensors arnt working and the ERG sensor isn't working either (I don't know what it does tho??) plus the coolant temp sensor has failed too.. Hmmm
    Jul 2011
    You can buy these items much cheaper than genuine at ECS tuning check em out!!!!
