Page 6 of 6 FirstFirst ... 456
Results 51 to 59 of 59
Thread: HELP! 1.6l to 1.8T conversion wiring issues....
  1. #51
    Jul 2009
    Geelong, Victoria
    ok, closer now:
    squirt fuel into the intake manifold and car runs until the ecu cuts it off
    hotwire the fuel pump and it doesnt....
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
  2. #52
    Aug 2011
    Canberra
    Is something shorting out the injectors??
    Possibly a loose earth / power connectors?
    Also, does the fuel pump 'prime' when you open the drivers door after unlocking the car?
    May also need to check the fuel pressure sensor as if it thinks there is full pressure, it may not turn on the fuel pump... Shouldn't stop the injectors though...
    '90 Mk I Cabriolet 1.8L - My toy... err... Daily driver... - Replaced with ‘93 Mk1 Cabriolet 1.8L <- Soon to be mine...
    '99 Mk IV Bora V5 <-- RIP - Replaced with ’10 Tiguan 147kw <-- Wife's Daily Driver
    '05 Volvo T5 S60 - 2.5L Turbo AWD Replaced with '09 Ford LV Focus Sedan <-- Used by the kids
    '07 Eos 2.0 TFSI - Project Eos...
  3. #53
    Jul 2009
    Geelong, Victoria
    Yes pump primes.
    My suspicion is an earth issue as well , either off the loom or bad ecu earth. Thanks for the suggestions
  4. #54
    Aug 2011
    Canberra
    If the fuel pump primes, and then doesn't run again, the car thinks it has full fuel pressure...
    I don't think it's the fuel pump circuit you should be looking at, but rather the ignition/injector circuit...
    If you plug a multimeter into the injector sockets, can you see a pulse when you crank the engine?
  5. #55
    Jul 2009
    Geelong, Victoria
    I tend to agree
    Yes, I get 5 volts with ign on and flickering wirh cranking
  6. #56
    Aug 2007
    Fuel pump relay wiring different in the A3 to the 1.8T, different ECUs . 1.6 is SIMOS and Motronic for the AGU. Some major players on the relay go to different spots between A3 and Golf. Pm sent with wiring suggestion, ill only complicate matters if i post it here.
    Jmac
    Alba European
  7. #57
    Jul 2009
    Geelong, Victoria
    All received Jmac - cant wait to get home and try this out!!!
    thanks Stan
  8. #58
    Jul 2009
    Geelong, Victoria
    SUCCESS !!! Got the car to run after changing a wire in the plenum chamber from the brown plug to the orange one, which involves the fuel pump relay! (purple/white)
    Thanks guys, especially Gav who spent a lot of time on the phone with me and Jmac who discovered the actual wire (after a fair bit of time checking out circuit diagrams - he is the wiring guru, will have to get this guy to chip it later).
    Also to Steve who offered me the chance to try his computer and check out his cars if need be.
    What a great forum
  9. #59
    Aug 2011
    Canberra
    Congrats mate... Glad it's all sorted...
