Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 59
Thread: HELP! 1.6l to 1.8T conversion wiring issues....
  1. #41
    Jul 2009
    Geelong, Victoria
    on vagcom today:
    in engine measuring block i got 200+ rpm on cranking - so crank position sensor semms to be working ok
    VCDS Version: Release 10.6.4
    Data version: 20110418
    TODAY'S SCAN:
    Monday,03,October,2011,14:59:37:48399
    Chassis Type: 1J - VW Golf/Bora IV
    Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
    76
    Mileage: 229400km/142542miles
    Address 01: Engine Labels: 06A-906-018-AGU.lbl
    Part No: 06A 906 018 AQ
    Component: 1.8L R4/5VT MOTR HS D06
    Coding: 04000
    Shop #: WSC 06313
    VCID: 71E2F7D51139
    9 Faults Found:
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    01249 - Fuel Injector for Cylinder 1 (N30)
    26-00 - Output Open
    01250 - Fuel Injector for Cylinder 2 (N31)
    26-00 - Output Open
    01251 - Fuel Injector for Cylinder 3 (N32)
    26-00 - Output Open
    01252 - Fuel Injector for Cylinder 4 (N33)
    26-00 - Output Open
    01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
    29-00 - Short to Ground
    01259 - Fuel Pump Relay (J17)
    28-00 - Short to Plus
    01262 - Solenoid Valve for Boost Pressure Control (N75)
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - - Intermittent
    Readiness: N/A
    Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
    Part No: 1J0 907 379 P
    Component: ABS 20 IE CAN 0001
    Coding: 03504
    Shop #: WSC 01317
    VCID: 3E781CE910E7
    1 Fault Found:
    00285 - ABS Wheel Speed Sensor; Front Right (G45)
    35-00 - -
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 6Q0 909 601
    Component: 0C AIRBAG VW5 0004
    Coding: 12355
    Shop #: WSC 01317
    VCID: F0E472D19A33
    No fault code found.
    Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
    Part No: 1J0 920 805 B
    Component: KOMBI+WEGFAHRS. BOO V01
    Coding: 03703
    Shop #: WSC 30071
    VCID: 254AD3859571
    Part No: Ident
    Component: Nr. WEGFAHRS.:VWZ6Z0Y1997147
    Ident.-Nr. WEGFAHRS.:VWZ6Z0Y1997147
    1 Fault Found:
    01176 - Key
    07-10 - Signal too Low - Intermittent
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 01317
    VCID: F0E472D19A33
    Address 46: Central Conv. Labels: 1J0-959-799.lbl
    Part No: 1J0 959 799 Q
    Component: 4C Zentral-SG Komf. 0001
    Coding: 04097
    Shop #: WSC 01317
    VCID: 4C9C4621565B
    Part No: 1J2959802C
    Component: 4C Tőrsteuerger. FS0002r
    Part No: 1J2959801D
    Component: 4C Tőrsteuerger. BF0002r
    Part No: 1J4959811C
    Component: 4C Tőrsteuerger. HL0002r
    Part No: 1J4959812C
    Component: 4C Tőrsteuerger. HR0002r
    1 Fault Found:
    00952 - Signal; Drivers Door Open
    28-10 - Short to Plus - Intermittent
    End ---------------------------------------------------------------------
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
  2. #42
    Jul 2009
    Geelong, Victoria
    the above seems a lot like a fuel pump relay fault - however mine is fine and so are the appropriate fuses.
    so perhaps there is a power issue somewhere....
  3. #43
    I wouldn't be surprised if it's just one wire off somewhere. The ECU isn't seeing the injectors. The other shorts need working out too.
  4. #44
    Jul 2009
    Geelong, Victoria
    I agree Gav, in fact if someone who knew them well could have a poke about I'm sure they'd get it running in no time. Trouble is, that's not me and all the good guys seem to be in NSW or QLD.
    There is no power to the fuel pump and no power at the injectors, it must be an easy fix, but I cant find it...
  5. #45
    Aug 2007
    Ok Stan ill have a look as i mentioned today. Ill probably speak to you again tomorrow.
    Jmac
    Alba European
  6. #46
    Jul 2009
    Geelong, Victoria
    thanks GAV and Jmac, you guys have been very helpful - beers for you when i get this going!
  7. #47
    Jul 2009
    Geelong, Victoria
    pump back to relay seems ok, battery to relay seems ok, all voltages are good. Relay is good, fuel pump good.
    that leaves comms between relay and ecu or a dud earth or something....
  8. #48
    Jul 2011
    just to get an idea did you only replace the harness outside the car or did you replace anything inside???
  9. #49
    Jul 2011
    check the 15 amp fuse S228 and terminal 1 on pump connector if you got power there relay is working with ignition on.
    you should also check fuses S243 10 amp and S234 10 amp these run of the same line which flow to the N80 and the N75 funny thing is
    this also flows to another fuse S232 10 amp which flow to the injectors. Hope this can help this is from a golf 1999 agu audi may be
    different i will check difference tomorrow.
  10. #50
    Jul 2009
    Geelong, Victoria
    thanks grtuned, i appreciate your help.
    replaced the two main bundles from the ecu. the rest is original. it's all pretty similar mate, thankyou.
    suffice to say I've been spending a lot of time reading diagrams and chasing wires
