check faults, cleared them and checked again:
VCDS Version: Release 10.6.4
Data version: 20110418
Thursday,22,September,2011,13:01:07:48399
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 229400km/142542miles
Address 01: Engine Labels: 06A-906-018-AGU.lbl
Part No: 06A 906 018 AQ
Component: 1.8L R4/5VT MOTR HS D06
Coding: 04000
Shop #: WSC 06313
VCID: 71E2F7D51139
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 P
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 01317
VCID: 3E781CE910E7
1 Fault Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45)
35-00 - -
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 601
Component: 0C AIRBAG VW5 0004
Coding: 12355
Shop #: WSC 01317
VCID: F0E472D19A33
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 805 B
Component: KOMBI+WEGFAHRS. BOO V01
Coding: 03703
Shop #: WSC 30071
VCID: 254AD3859571
Part No: Ident
Component: Nr. WEGFAHRS.:VWZ6Z0Y1997147
Ident.-Nr. WEGFAHRS.:VWZ6Z0Y1997147
1 Fault Found:
01177 - Engine Control Unit
65-10 - Unauthorized - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01317
VCID: F0E472D19A33
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 Q
Component: 4C Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 01317
VCID: 4C9C4621565B
Part No: 1J2959802C
Component: 4C Tőrsteuerger. FS0002r
Part No: 1J2959801D
Component: 4C Tőrsteuerger. BF0002r
Part No: 1J4959811C
Component: 4C Tőrsteuerger. HL0002r
Part No: 1J4959812C
Component: 4C Tőrsteuerger. HR0002H
End ---------------------------------------------------------------------
I expect the ABS faults as the sensors are unplugged whilst I am doing the suspension.
using the 1.6 key and ignition, original 1.6 cluster, and the 1.8t ecu...
It wont work.
You need to have the Key, ignition, cluster and ECU all the sync.
The only was around it will be to get an IMMO delete or something coded from the stealership. (Pretty sure they can sync it all if you can prove ownership.)
i thought as much, but cant vagcom put them all together - the ecu is the only odd one out in the group - key, ignition and cluster are all original....
I'm not sure, that is above my head. I am using all donor car gear.
I am an utter noob when it comes to this kind of stuff but an immo defeat on the ECU would be a good place to start. Possibly get the ecu flashed with an upgrade and an immo defeat at the same time![]()
2003 Bora 4Motion
yeah JD i know what you mean
Easy enough if you are swapping the lot, no compatability issues
Colaron, what you say makes sense, but only the ecu is new so surely vagcom can sort this out....i could well be wrong
other thing is that the car is undrivable, so i cant take it anywhere
i erased learnt values and did the ecu swap sequence that ross tech advise, and still no luck
current fault codes for any gurus out there - suspension is off , so ABS codes are expected:
Monday,26,September,2011,20:16:43:48399
76
Coding: 04000
Shop #: WSC 06313
VCID: 71E2F7D51139
Readiness: N/A
Coding: 03504
Shop #: WSC 01317
VCID: 3E781CE910E7
1 Fault Found:
35-00 - -
Coding: 12355
Shop #: WSC 01317
VCID: F0E472D19A33
Coding: 03703
Shop #: WSC 30071
VCID: 254AD3859571
Part No: Ident
Coding: 00006
Shop #: WSC 01317
VCID: F0E472D19A33
Coding: 04097
Shop #: WSC 01317
VCID: 4C9C4621565B
Part No: 1J2959802C
Part No: 1J2959801D
Part No: 1J4959811C
Part No: 1J4959812C
Component: 4C Tőrsteuerger. HR0002r
From the rosstech site...
The bold bits from above... did you do this?Before Installing a USED ECU (we'll call it ECU #2) in vehicle, get the ECM coding from the current ECU (we'll call it ECU #1) in the vehicle
[Select]
[01 - Engine]
Write down the 5-digit Soft. Coding
[Close Controller, Go Back - 06]
Install the USED ECU (ECU #2) in vehicle, (the Immobilizer light will be flashing, that's okay for now)
[Select]
[01 - Engine]
Write down the 14 digit Immobilizer ID number from the "Extra" field. This the 14 digit Immobilizer ID number for ECU#2.
[17 - Instruments]
Write down the 14 digit Immobilizer ID number from the "Extra" field. This the 14 digit Immobilizer ID number for ECU#1.
VW/Audi used to give out the 7 digit SKC to vehicle owners but as of 2005 they no longer do. Unless you already have that information, then you will not be able to use these instructions - you will likely need to have your dealer perform this procedure.
Measure the car's battery voltage, it must be 12.5 V or higher.
With the USED ECU (ECU #2) in vehicle, (the Immobilizer light will be flashing, that's okay for now)
[Select]
[01 - Engine]
[Login - 11]
[Use 7-digit PIN/SKC]
Enter the 7-digit PIN from ECU #2, Date on which the PIN was GENERATED BY THE DEALER, along with the dealer's Workshop Code (WSC) and the Importer number
[OK]
[Do-It!]
(You just "introduced" yourself to ECU#2 and the ECU should listen to you since you knew how to login. The ECU is now ready to learn its new home.)
[Adaptation - 10]
Enter 50 in Channel Number
[Read]
Enter the 7-digit PIN from ECU#1, Date on which the PIN was GENERATED BY THE DEALER, along with the dealer's Workshop Code (WSC) and the Importer number
[OK]
[Test]
[Save]
[Done, Go Back]
(You just told ECU#2 that it has a new home, and that it should make friends with the Instrument Cluster.)
Verify that the VIN now displayed in the "Extra" field in the Engine matches matches the VIN now displayed in the "Extra" field in the Instrument Cluster controller.
Turn ignition OFF and then back on within one minute, but do not start vehicle for two minutes
After 2 minutes, start the vehicle
[Select]
[01 - Engine]
Verify that the 5-digit Soft. Coding matches the coding from the old ECU
[Fault Codes - 02]
Clear all DTC's.
2003 Bora 4Motion
