any auto elecs want to help me out, it's 90% there.
it's my daily driver as well, started this on leave and now it's over, wifey is not impressed![]()
Hi guys, i need the help of a wiring guru.
I have a 2000 1.6 Golf AKL engine and am mid conversion in putting a 1999 Audi 1.8T AGU.
Yes there is a pending build thread....
I have the entire Audi subframe and changed the lot over, including ECU and its looms - a big enough job
However the plugs that go into the rain tray are slightly different - original being orange , brown and white, and new being orange , green and white. all but a few wies match, but I think that is where the trouble lies...
The engine cranks, but doesnt fire (should at least run for a few seconds even if the immobiliser is locking me out...).
Fuel pump doesnt run - but a hotwire to the pump and it does - fuel pump ok. Interestingly with a multimeter it shows only about 5 volts at the pump with the key on and cranking.
ah ha, you say - the fuel relay. Well it clicks with the key on and off - so not totally stuffed (and worked fine before the change...) - I will replace it anyway.
Any other ideas? Specific wiring diagrams for the 1.6 and 1.8 would be nice - but they need to cover the exact years and models as there were some wiring changes at about year 2000...
i have the Bently pdf for Golf mk4 - but it doesnt cover the 1.6 and it's 1.8 section wiring is inaccurate for the 1999 Audi A3.
I have access to vagcom if required, but havent used it before.
This car is so close, but now I'm going f#$king nuts and am dreaming about wiring, relays and cars that wont go.
What was changed into the Golf was the entire front subframe, ecu and the two main looms from the ecu.
Any help greatly appreciated
Have you verified that all the basics are working?
Are the plugs getting spark? Is the ecu getting power? Injectors operating?
I realise these are basic things, but diagnosing this issue may be impossible over the net.
Nice project btw!
MKV Golf 2.0 TDI DSG Sportline. Just nice.
If you have vag com erase faults then see what faults are still there this may be able to pinpoint which direction to take,
If you can upload log of faults to thread..
1,8l Motronic (AGU)1.pdf
1,8l Motronic (AGU).pdf
One of these diagrams might be of use.
thanks guys, I'll run some tests, log faults and see what happens next.
Thanks for the pdfs Gav!
I presume you are talking about the wires that run into the white box in the rain tray on the driver side?
As far as I am aware these are just communication wires. However they are the only plugs that run into the cabin so they must have something to do with the fuel pump issue.
I've just done the 1.8t conversion myself if you have any questions please feel free to PM me.
pm sent mate
Alba European
@ James D : yes the white box in the rain tray and the asociated plugs. Thanks for the offer mate, I probably will send a PM
Thanks Jmac
