Is something shorting out the injectors??
Possibly a loose earth / power connectors?
Also, does the fuel pump 'prime' when you open the drivers door after unlocking the car?
May also need to check the fuel pressure sensor as if it thinks there is full pressure, it may not turn on the fuel pump... Shouldn't stop the injectors though...
