Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 59
Thread: HELP! 1.6l to 1.8T conversion wiring issues....
  1. #21
    Jul 2009
    Geelong, Victoria
    thought so - perhaps i got it wrong.
    I have that cut , pasted and printed out....lol
    thanks for your help mate
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
  2. #22
    Apr 2011
    Ipswich, QLD
    Some more info Immobilizer - Ross-Tech Wiki
    You definately need these SKC's... from both ecu's by the looks of it. I would be heading to the local dealer and asking real nice if there is any way they can help... remember to take knee pads
    2003 Bora 4Motion
  3. #23
    Jul 2009
    Geelong, Victoria
    sounds like a plan lol
  4. #24
    Jul 2009
    Geelong, Victoria
    according to the table in the link i dont need an skc for swapping a used ecu..... mine is an immo 2
  5. #25
    Apr 2011
    Ipswich, QLD
    If both ECU's are immo2 this looks like the procedure but looks a little light on details.
    ECM Matching
    Prerequisites:
    Battery voltage at least 12.5 V.
    Immobilizer II ECM
    [Select]
    [17 - Instruments]
    [Adaption - 10]
    Leave channel at "00"
    [Read]
    [Save]
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    [Exit]
    Turn ignition OFF for 15 seconds. Start vehicle.
    Notes:
    For cars with a separate Immobilizer (Includes 2000+ EuroVan, Cabrio, and many older non-US models), use [25 Immobilizer] instead of [17 - Instruments]. The rest of the procedure is the same.
    On some Euro Audi models with Immobilizer 2, the PIN/SKC will be required.
    On NAR market Cabrio models produced after 05/1999 the PIN/SKC may be required.
    Activating Cruise Control on a new ECU (DBW)
    DBW (Drive-by-Wire) Factory fresh ECU's often come with cruise control de-activated.
    [Select]
    [01 - Engine]
    [Login - 11]
    Enter 11463 to activate cruise control
    [Do It!]
    Note: See this page for additional CCS details: Checking Cruise Control using Measuring Values
    Coding
    The new module will need to be coded. Enter the coding from the original module if possible. If the original module is not available, or did not communicate, refer to the coding chart in VCDS or the factory repair manual.
    We are europe as far as VAG goes...
    2003 Bora 4Motion
  6. #26
    Jul 2009
    Geelong, Victoria
    thanks mate, still not running...
  7. #27
    Jul 2009
    Geelong, Victoria
    thanks, will look into this!
  9. #29
    Apr 2010
    Gold Coast, Queensland
    Apparently SKC's aren't just thrown around buy the stealership anymore. They pump in some number and letters into their computer something funky happens and sends it to a device that they then plug into something an wolla.
    Avoiding anyone to see the SKC.
  10. #30
    Jul 2011
    yYou may have to tow to the dealership and have them authorise the ecu this is done with there equipment all at once during the process, i'm sure test plans for adapting immob items ask which component is new and then it codes it to suit the rest.
