Results 1 to 7 of 7
Thread: Is heat proof paint necessary for painting hubs and spacers?
    Jan 2011
    Bundaberg
    Hi - I want to paint my hubs and spacers the same colour to make them less obvious - can I use normal paint or do I need heatproof caliper paint for this purpose? Any ideas?
    Aug 2007
    Perth, Australia
    have you tried touching your wheels after a good spirited drive?
    1991 BMW 318is RED E30
    Erskineville, NSW
    it depends how you drive.
    i've done my hubs & calipers in the past with standard pressure pack & they've been fine but if you tend to get up it a bit then you'll need paint that will take some temp.
    heat proof will probably be cheaper and less effort in the long run
    Jan 2011
    Bundaberg
    cheers, thanks for the advice guys :-)
    Time to visit supercheap and the 3m aisle...
    UOTE=mikk;819142]heat proof will probably be cheaper and less effort in the long run[/QUOTE]
    Jun 2011
    i'm with Brad on this one.
    depends on how you drive... but considering you should really heat up your brakes when bedding in the new pads normal paint will flake off if you are doing this properly.
    the extra cost is worth the time and effort when having to redo this job.
    Dec 2006
    Kilsyth, VIC
    Is the cost differential really that much? Or is it about the colour you want not being available??
