Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Headlight wiring
    Jul 2007
    Brissy
    Find the correct wire for the parker light on the back of the light switch, pull the pin and connect it to an switched + source.
    There is a distribution panel under the drivers side of the dash.
    Yellow connector on the left is ignition switched 12V+
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Apr 2008
    Quote Originally Posted by Wighty654 View Post
    I'm not sure this would work but couldn't you just run a wire that provides them with power using the same feed as something like the stereo that comes on with the ignition?
    Absolutely - just find a wire that carries 12v on "ACC" and use that to power the angel eye ring rather than the parker circuit.
    Nothing to see here...
