![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
sierra055
Yeah, unfortunately has to come out. I've gotten to be pretty practiced at it lately with headlight, SMIC installs etc.
It's really pretty basic.
Remove the 2 plastic grills in the front left and right of the bar. There are 2 tabs on each one that you push down, then pull the grill toward you.
Unscrew the Torx screw in each. Don't forget to unclip the temperature sender in the passenger side one!
Remove the centre grill (where VW badge is)
To do this, there's a little tab just on the top centre, push this with a flathead screw driver.
Next, remove the bonnet release. To do this, I use a small flat head and seperate the 2 sides away from the release.
On the top left and top right of the grill are two clips, just pull the grill back toward you and they should pop out.
Lastly, the bottom clips. Just tilt the top of the grill toward you and pull up.
There are now 5(?) Torx screws to remove across the top of the bar.
Next, you'll need to turn the wheels full lock to the left, then the right to remove the 4 lowest Torx screws from the wheel liner and the bar.
Next, have someone assist to pull the bar straight back. It might be a little hard at first, VW have a cool seating system so it locates perfectly back in. Just pull straight back from the wheel well toward you each side at a time.
Fitting is the reverse.
