Results 1 to 10 of 15
Thread: Headlight Buzzer (when you leave the lights on)
    Oct 2009
    Torquay victoria
    2003 Mk iv Golf manual 1.6 SE
    Love it, cheap to run and fun to drive.
    I have some nagging issues though:
    The Headlight buzzer is spasmodic, any ideas? sometimes it works some times it doesn't, that is when I turn the motor off with the keys in the ignition and the headlights still on.
    The central locking relocks after unlocking sometimes in as little as 10 seconds, I know a lot of modern cars do this but 10 seconds What the?
    and the radio has just gone kapoof, cheap Eurovox , any suggestions ? for a replacement
    Andrew
    Quote Originally Posted by Andrew_Geo View Post
    not sure, but something to note, if you turn the car off with the indicator on, you'll hear the same buzzing sound because i believe this turns on your parker light on the side you flick the indicator towards.
    sounds about right, maybe just a touch short, if you're concerned its not right get an exact time and someone here can compare theirs. if you're walking towards the car, the buzzer works about 30 meters away, and there is usually enough time to make that walk unless you fiddle around for a bit. i've been done a couple times but it's not that hard to press the buzzer again.
    depends on your budget, heaps to choose from. i've always gone for Pioneer Head units. some ideas on prices.
    http://www.ryda.com.au/Car-Stereos-C...Store-s/20.htm
    actually my factory cd player/radio had a broken display, wasn't bothered because i was always upgrading the stereo.
    Nov 2006
    Brisbane Qld
    There is a microswitch in the drivers door lock that is playing up.
    Could just have dirt in it or has a dry solder contact inside lock if you are lucky.
    Plenty of threads on vortex about this issue.
    VW will try to sell you an entire lock assembly to fix it, but you can just buy a new microswitch from Jaycar/**** Smith/ ebay for example
    Perth WA
    Andrew
    Sounds like my issue in an '01 Bora.
    It's most likely the door open sensor, i.e. it does not know when you open the door to get out.
    I left my lights on once recently due to this (the issue has just started recently, buzzer used to work ok), also same as you, you unlock the car, and if you don't start the car within 30 seconds or so the doors will lock again (Again, it does not know you have got in).
    Another symptom is the light on the lower part of the door does not come on when the door is open.
    Apparently the sensor is inside the lock / handle?
    Anyone fixed this issue? - I did read recently it is usually dry joints in the small circuit board that is the issue. (I also read there were 4 micro-switches in there ??)
    Any tips/ links would be handy - was actually going to attempt this afternoon but not sure I have the time
    Keith
    Nov 2006
    Brisbane Qld
    Haha Mr Smith (the electronics guru) seems to have an offensive first name.
    Nov 2006
    Brisbane Qld
    May 2007
    Jimboomba. QLD
    door locks
    Hi, I had an issue the other day with the interior lights not coming on when I opened the passenger side front door.
    I found it was a sticky door catch not triggering the internal switch...all the dust around I suspect.
    I simply squirted some CRC (WD40 will do the same) around the actual door catch area...I didn't pull the door apart or anything... and it fixed the issue.
    With all the dust around I expect we could see a lot of these little issues coming up.
    2010 90TSI Manual / Comfort Pack / United Grey
    RICE - Leave the useless wings to the Penguins...
    Oct 2009
    Torquay victoria
    less than adequate solder job.
    Graeme86,
    thankyou very much, it would seem that 2003 , there was the same problem, has there been a recall on this??
    Andrew
    Nov 2006
    Brisbane Qld
    Not as far as I know.
    They just used the same crappy design all the way through...just like the window regulators.
    May 2007
    Moonee Ponds
    yah they dont care, no laws that they have to fix this.
    I wonder what ACC would say hmmm hhmmm
    Audi B4 80 Q V6 '94 Race Car !! KEGGED
    Audi B4 80 V6 Avant '94 Only one in the country that I know of !!! KEGGED
    Subaru Forester XT '06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
    --VW Bora V6 4mo '01 Gone
