Results 11 to 20 of 25
Thread: Headlight Bulb recommendations
    i have narva ones first set was there brightest legal bulbs, were great but ended up in my gfs mirage as hers sucked.
    i then for the next brightest (closer to white), they look nicer but the light seems to just bounce off the road and not light it if its raining.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Apr 2008
    Quote Originally Posted by JustCruisn View Post
    Philips Xtreme are great.
    Golf headlights have separate bulbs for everything. 4 bulbs each headlight.
    Except he has a Bora, which has combined normal/high beam.
    Nothing to see here...
    Mar 2010
    Lesmurdie
    Well i got a set of the x-treme vision and well im a bit disappointed. They don't seem to do that much more than the OEM bulbs (osram bilux) But i could be wrong
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Apr 2008
    Quote Originally Posted by Back Door Shenanigans. View Post
    My Philips X-Treme Power bulbs were considerably better than the OEM ones (I even tried a new set of OEMs first).
    You will NOT get HID-like levels of lighting out of standard incandescent bulbs though.
    Oct 2010
    Yarra Valley, VIC
    Well after driving quite abit at night with my Osram Nightbreakers v2 I think they are worth every dollar.
    Nice white light and considerably better range.
    2014 MK7 R
    2014 Audi SQ5
    2022 Tiggy R
    2022 Tiggy 162 Allspace
    Mar 2010
    Lesmurdie
    Quote Originally Posted by Manaz View Post
    Yeah i know that, still nothing compared to my dads euro. But it says on the box that it has 100% more light but still throws the same distance and pretty much the same brightness. I had one installed and the other OEM and couldn't really tell the difference.
    Jun 2011
    O'Connor, ACT / Balmain, NSW
    shenanigans, did you fit them yourself ? I just ordered a set and reckon i could put them in myself. Then someone said I should get them properly aligned at a garage. But the youtube videos seem to be pretty straightforward. Is there anything i need to look out for ?
    '01 Saab 9-3 S
    past rides: '01 Bora 4motion, '03 Golf Sport 2slow, '92 Ford Laser GL wagon (caught on fire)
    Aug 2007
    Five Dock, Sydney
    I fitted a set of Extreme Vision H4 in my Bora before my trip up north and i found them to be very satisfactoryboth on highway and in the forest
    '03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
    Mar 2010
    Lesmurdie
    Quote Originally Posted by governor22 View Post
    Nah easy enough just a bit of stuffing around getting trim pieces off. Don't touch the glass and you should be fine. Shouldn't really need to align them again
    Jun 2011
    OK, I'm not sure if I've done something wrong, but my Philip X-tremes are a HUGE disappointment.
    more specifically-
    on low beam they're quite good, you can see a brighter beam than the old ones, but that's about the only good thing. I flicked the switch to high beam, expecting to see to the end of the street, and nothing changed. The 'direction' of the rays in front of the car changed, but it's like the beams are going up into the sky or something, cos they ain't lighting up **** on the street...
    I'm thinking maybe I didn't put the globes in properly, but there's only one way they fit in, and it's not like the side they're facing when sitting in the globe bay matters, right ?
    at this rate, i'm considering swapping the old ones back in. Such a pain in the arse though, cos it took me 2 hours to put the new ones in !
    '01 Saab 9-3 S
