I have the worst squeek in the stereo head unit in the Gti. If anything drives me nuts its rattles and squeeks. I have put foam in under the headunit before which hellped but didnt fix.
I cant get the head unit out of its mount. Do i need a special tool or what?
2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
"Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
Okay, easy. Got some wire the same size as the 4 holes on the front of the head unit and jammed it in there. By removing the Climate control i could get in behind the head unit to push (a little bit difficult to pull from the front of the unit).
I then removed the head unit, and the tray above it. I had to fill in the top of the tray (has venting holes in it) so i could use it upside down. So the tray has now replaced the position of the headunit, and the head unit sits on the very top making it a hell of a lot easier to hit the buttons on it.
AND... it doesnt squeek anymore!
