Results 1 to 4 of 4
Thread: Head Unit Removal... How...?
    Sep 2006
    Leppington NSW
    I have the worst squeek in the stereo head unit in the Gti. If anything drives me nuts its rattles and squeeks. I have put foam in under the headunit before which hellped but didnt fix.
    I cant get the head unit out of its mount. Do i need a special tool or what?
    Dec 2007
    Brisbane, Southside...
    Quote Originally Posted by peteon2wheels View Post
    I'm pretty sure that you need a tool. This tool is dependant on the headunit that you have. You'll have to go on a hunt to find the tool.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Sep 2006
    Leppington NSW
    Okay, easy. Got some wire the same size as the 4 holes on the front of the head unit and jammed it in there. By removing the Climate control i could get in behind the head unit to push (a little bit difficult to pull from the front of the unit).
    I then removed the head unit, and the tray above it. I had to fill in the top of the tray (has venting holes in it) so i could use it upside down. So the tray has now replaced the position of the headunit, and the head unit sits on the very top making it a hell of a lot easier to hit the buttons on it.
    AND... it doesnt squeek anymore!
    Jun 2006
    Orange NSW
    Good stuff mate. That's the correct way to do it. .
