Results 1 to 10 of 15
Thread: Head unit not working
    Hey guys,
    Just randomly after using the radio this morning, my head unit has stopped working and will not power on anymore. I have a pioneer head unit installed and I have tried reinstalling my stock stereo and that too has no power when car is on and off. I have tried changing fuse number 42 but still no luck. Does anyone know what the problem could be or has anyone experienced something similar?
    Thanks
    Jul 2013
    Melbourne, VIC (NE 'Burbs)
    I guess check the other fuses, or measure the voltage on the supply pins at the radio head unit connectors with a multimeter when the accessory power is on.
    Edit: some headunits have a fuse on the back of them, perhaps check those as well. Once you find the problem, then it will be easier to fix and prevent from reoccurring.
    From the diagram below, looks like you'll want to check the voltage on pins 7 & 8 on the black connector.
    Head unit not working-page-5-lr-jpg
    2003 Bora MK4 V4/2.0L GL
    [N/E MELB] VW MK4 Immo Key Recovery & Coding
    Quote Originally Posted by pinchies View Post
    Thanks for the information, I think there might be a problem with pins 7 or 8 but if that is the case how would I resolve this issue? I don't think there is much, if any power going through these pins into the head unit.
    Jul 2013
    Just check em and see what the voltage is. If there is no voltage at all (most likely I think if both h/u are not working!) its 99% certain to be a fuse somewhere else, but if there is a voltage then its something else probably to do with another wire, and you would need to find someone else who knows more about it than I do.
    Your battery hasn't run flat recently or anything like that?
    No my battery hasn't run flat, everything else inside seems to work fine except the head unit. Hopefully the problem lies within another fuse.
    Thanks anyway
    Jul 2013
    I'm too busy at the moment with uni, or I'd offer to help you out personally -- if not sorted in a few weeks, let me know. If you don't have a multimeter, I would highly recommend getting one, as they are handy for all electrical stuff, will save you time with this kind of thing, fairly cheap, and easy to learn how to use.
    I'm in a similar position with year 12 exams coming up but thanks for the offer. I did just recently purchase a multimeter but hasn't delivered yet but will be sure to check out the pins and fuses as soon as it arrives.
    Jul 2013
    Ok! Well good luck with school, and once the meter arrives can walk you through what to do.
    Apr 2011
    Berwick, Victoria
    Try fuse 42 (25amp) (panel of the right of the dash)
    http://www.mikegabriel.net/vw/bentle...%20General.pdf
    If you already have the head unit pulled out, plug it back in and bridge the red & yellow wires (this will confirm the fuse is toast if the unit switches on)
    Quote Originally Posted by MCiN7 View Post
    I have tried replacing fuse 42 and the head unit will still not power on as mentioned above
    Quote Originally Posted by PrOxIMPURE View Post
