I guess check the other fuses, or measure the voltage on the supply pins at the radio head unit connectors with a multimeter when the accessory power is on.
Edit: some headunits have a fuse on the back of them, perhaps check those as well. Once you find the problem, then it will be easier to fix and prevent from reoccurring.
From the diagram below, looks like you'll want to check the voltage on pins 7 & 8 on the black connector.
2003 Bora MK4 V4/2.0L GL
[N/E MELB] VW MK4 Immo Key Recovery & Coding
