Results 1 to 10 of 18
Thread: HEAD GASKET Bora 2.8 experience...anybody?
    Jan 2016
    gold coast qld
    Anybody blown a head gasket on the bora V6 before or seen the aftermath? Any obvious tell tale signs?
    Dec 2008
    Sydney/Canberra
    What are the symptoms you're experiencing with it?
    Jan 2016
    gold coast qld
    Start from beginning...
    So I bought a 4 motion with the diagnosis being the injector drives faulty in the ECU. All indicators pointed to this when I took possession as it was pissing out fuel from the exhaust ad running rough. So I bought another ECU and with the wonderful help of Gav from" OPTIMUM CODE" he switched the ignition chips and coded the ECU to working order. I then installed the new ECU and It ran better but still horrible! Took it for a drive and it didn't have the power to get up the hill to get back my house. Blowing white/grey smoke and when I checked the coolant resivour it had lots of tiny bubbles in it. Next point of call was to check coils and plugs to see if any moisture/ coolant was visible but strange enough there was not even a sceric of moisture? Oil seems fine without any visible signs of water or moisture mixed in.
    So that's where I am at the moment. I'm baffled really as some signs say yes it's head and some signs say not really?
    Dev.
    Dec 2008
    Sydney/Canberra
    Could always do compression and leak-down tests, and maybe test the coolant for carbon monoxide contamination.
    Has it been scanned yet With the new ecu?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jan 2016
    gold coast qld
    Mate i have not scanned after new ecu install, the codes before we cleared where-
    Attachment 27043
    Oct 2016
    If it had blown a head gasket, you'd have a nice white milkshake under your oil cap, and the temperature would be going north.
    | 2016 VW Golf R 7 | DSG | Pure White | Leather | Sunroof | Driver Assist | JB4 |
    | 2003 VW Golf SE | Auto | Silver | Sunroof |
    | 2010 VW Golf R 6 | Manual | Leather | ACC | 19s | Black Pack | GIAC Stage 2+ |
    Peregian Beach
    The easiest way to diagnose this is to go to a radiator shop. They can test for exhaust gas in the coolant as suggested by Umai Naa!!. Bubbles in the coolant and steam out the exhaust are other signs. Generally a blown head gasket will pressurise the radiator/and the coolant level will go down and the temperature will go up.
    You won't tell anything by looking at the coils but you might be able to suss something by looking at the condition/colour of the park plug electrodes. You don't necessarily have to have water in the oil with a blown head gasket. It depends where the gasket has failed.
    Dec 2008
    Sydney/Canberra
    Spot on.
    The last one I did, failed at the combustion chamber. So low compression, but no milkshake in the coolant. The combustion pressure just pumped the coolant out the overflow bottle.
    Apr 2014
    Penrith, NSW
    I'll be following this one closely Dev as I think mine head gasket went kaput yesterday also.
