Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Hazard switch ticking
    Mar 2010
    Lesmurdie
    Yay, Managed to fix it with some contact cleaner into the end of the stalk nearest the steering wheel. Cheapest and easiest fix so far on the car. Just remove the top plastic and spray into the end and wait an hour. Seems to fix it so far.
    Cheers all
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Mar 2010
    Reviving a really old thread
    My golf just started doing this a week ago. Sometimes it seems like the sound is coming from in the dash (behind the hazard light switch) other times it sounds like it's coming from in near the indicator stalk.
    I'm going to try the contact cleaner on the indicator stalk before I worry too much about whats in the dash. I have two questions. Firstly, whats the method for getting the top panel off the steering column? Secondly, if I have to get into the dash behind the hazard switch is there an easy way to do this?
    Thanks for all your help!
    Mar 2010
    Lesmurdie
    Quote Originally Posted by clark View Post
    When i did my fix i really didn't have to take any thing off (i did but it didn't help). Otherwise if you do its just the screws underneath the steering column. All i did was sprayed it with a straw where the end of the stalk is (In the steering column).
    The hazard switch and all that should pop out. Heres a picture if it helps.
    Mar 2010
    Quote Originally Posted by Back Door Shenanigans. View Post
    Thanks mate! Thats really helpful.
    my hazards button started clicking not long ago, but seems to have stopped again.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Oct 2010
    Hey backdoor! I've just fixed this as well but my hazard lights aren't actually working so the Hazard light switch needs to be replaced. How did you actually get all of those switches out of the dash?
    Mar 2010
    Lesmurdie
    Sorry for the late reply haha. Ah you very very gently (Or with a plastic thing) pry them out using a flat screw driver. They are held in with two metal tabs either side
    I.E
