Results 1 to 10 of 17
Thread: Hazard switch ticking
    Mar 2010
    Lesmurdie
    Hey,
    So i have a weird problem at the moment with my hazard and indicator relay making the ticking noises at random times and random speed. The indicators and hazard switch still works fine but mainly after using them does it make the ticking noise.
    I sorta had a look at the connection and pushed it in but seems to not have worked.
    Any tips?
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Jul 2007
    Brissy
    Sounds like the relay is failing.
    The tick sound is the relay contacts opening and closing.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Sep 2009
    I had the exact same problem! My problem was the indicator stalk, VW diagnosed (dont know how) and wanted me to give them my arm for a new one so instead i went to **** smiths and bought a can of CO Contact Cleaner (N1072) | **** Smith Online Store and sprayed it down the indicator stalk into the assembly. Be warned its apparently very very highly flammable and some people thus recommend unplugging you battery when you do it!
    I however just had the car off, sprayed it down there with the indicator stalk in various positions (dont pull on the high beams). After letting it sit for the time given (i'm assuming to let fumes etc to clear) i tried it and all was well. No more erroneous ticking
    Aug 2007
    Perth WA
    Where is the ticking coming from? The relay switch is behind the Hazard button, not the indicator stalk.
    I had a similar thing with the relay last year & the indicators (in the dash cluster at least) would flicker on & off too. Fortunately it stopped after a few occurances and hasn't happened since!
    I did find a leak in my windscreen seal around the same time so it's possible a bit of water had run down behind the dash and caused a hiccup, but that could be coincidence too...
    '04 BMP MkIV R32 #144
    search getnew
    Mar 2010
    Lesmurdie
    its coming from the hazard switch not the indicator stalk and the indicators arn't going off neither are the dash lights. Ill give the stalk idea a shot i guess if it doesnt stop anytime soon.
    Apr 2010
    Sydney,NSW
    Just a thought, it's not the air direction flap servo clicking is it? I had that once, a clicking from the dash that sounded like it was around that area.
    Does it stop if you put the air flow on to recirculation?
    Adam
    2012 Subaru WRX STi Spec-R in "Lightening Red" because red cars are the fastest!!
    Previously -
    2007 EOS 2.0 TFSI Indium Grey ~ Photos Here
    2002 Bora V5
    Sep 2009
    Mine was also the hazard switch ticking as the flasher / relay for the indicators is there. My indicators also weren't flashing when the ticking was occurring and there was no sound coming from the indicator stalk (nothing there to make a sound anyway).
    Few links that made me confident it was the stalk after the dealer diagnosed it as that (i thought it was the relay at first too)
    Indicator clicks constantly! - SEAT Cupra.net - SEAT Forum
    Turn signal relay (flasher button) clicking
    Mar 2010
    Lesmurdie
    Nah i can feel the relay ticking through the button when its clicking.
    Cheers i think il take it out and spray some contact cleaner on it first before i buy anything
    Jul 2007
    Launceston
    The same thing happened to my MK4 Polo - the flasher relay had to be replaced. I took it somewhere (i am hopeless at fix-it-yourself) cost about $40. When i pressed the hazard light button, it ticked normally. The dash lights (blinker ones) would flash dimly but the actual light bulbs on the car wouldn't turn on unless i asked them to (hope that makes sense - i'm not technically minded at all...)
    I'm going to the pub... I may be some time...
    Peregian Beach
    My Bora does the same thing. The dealer diagnosed it as the flasher stalk. I haven't done anything with it as yet. As none of the outside lights flash when it clicks i have just learned to put up with it for the moment. It doesn't do it all the time.
