Page 18 of 21 FirstFirst ... 81617181920 ... LastLast
Results 171 to 180 of 205
Thread: Hayden and Cliffos Mk4 R32 build
  1. #171
    Jun 2011
    And they are on. They weighed 100g less than a slightly worn OEM disc. So not a massive saving. But a fair bit bigger, so hopefully a little more rear bias from the extra leverage.
    Still look quite small under a 17” wheel. Any bigger of a disc and it would need to use an aftermarket caliper. At this stage it’ll suffice, I’d love to go to a Nissan/Subaru 2 piston caliper, but not keen on losing the handbrake just yet.
  2. #172
    Jun 2011
    Size comparison of the standard 256mm and the 298mm rotor.
    And a mid install pic
  3. #173
    purdy! They do oddly look lost in those wheels.
    double take and see how close the caliper is to the inside of the barrel
  4. #174
    Jun 2011
    I have only ever had the max amount of neg camber allowed with the R32 control arms.
    Without spending big coin on tubular control arms. I came across a popular method in the UK, which is to use MK2/8J TT ball joints.
    Now I was in a bit of a rush to get it all done after work so didn’t take any pictures going through the process.
    But as you can see they are a fair bit larger/longer than the stock items.
    You do need to drill a hole to line up with the MK4 control arms.
    And the end result is quite noticeable.
  5. #175
    Good work! Keen to see pictures of what needs drilling next time you are under the car.
    Ready for all the camber car meets!
    Sent from my HTC 2PZC100 using Tapatalk
  6. #176
    Jun 2011
    If you look at the photo of the ball joint. You can see the bolt isn’t in the slotted hole.
    The ball joint needs to be drilled there to fit.
  7. #177
    brisbane
    Nice work on the ball joints mate, keen to learn more about the new rear brake set-up if you have any part numbers please...
  8. #178
    Jun 2011
    Quote Originally Posted by guile View Post
    Have included the link to the online store below for the rear hats and adapters. He sells a lot of other cool bits as well!
    CB Auto. 300mm Alloy Bell
    CB Auto. S4 Rear Disk Conversion
  9. #179
    Ah yes.
    Was it a completely fresh hole or overlapped the orginal one?
  10. #180
    Jun 2011
    Ah yes.
    The one photo I found of the new hole, was elongating of the slot inboard.
    But I was able to drill a new hole next to the slot.
