Page 15 of 21 FirstFirst ... 51314151617 ... LastLast
Results 141 to 150 of 205
Thread: Hayden and Cliffos Mk4 R32 build
  1. #141
    nsw
    Nice. Is the shank diameter of OE gear stick the same as on the 1.8T 20V cars Hayden. Reckon that would fit the Golf 4/Polo 9N3 too?
  2. #142
    Jun 2011
    Quote Originally Posted by sambb View Post
    Yeah it’ll be the same diameter as R32.
    The shifter came with a variety of adapters, one would work with the VW shifter if you ran a dye over it to thread it. I have for now just used the grub screws included with loctite and no adapter. It’s tight and so far no issues but time will tell if the grub screws back out or not.
  3. #143
    Jan 2010
    Melb Westsideeeee
    Exhaust is schmickkkk dude.
    Also love the shifter setup, that was my intention as well as its all adjustable and looks pretty sweet. Try a skunk2 weighted knob with that shifter combo, feels real good. Also the DG shift kit will REALLY improve things too, cant recommend it highly enough.
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
  4. #144
    Jun 2011
    Quote Originally Posted by GeorgeMK1 View Post
    Thanks George! Sounds pretty good for a 24v.
    This knob is a hefty 350g, something a tad lighter might be better. But for now I’ll get used to it. Pretty handy arm rest.
  5. #145
    Jun 2011
    Racecar fridays!
    Still a suitable vehicle to get to work and back.
  6. #146
    Jun 2011
    A few more drives on it, and sorting out a few teething issues. The new O2’s didn’t work at all (crap eBay stuff) so swapped out the other day and all working good again.
    Having a ‘dead’ or heavy spot sometimes in the steering at low RPM’s, I’m thinking it’s because of the mismatched pulley setup I have going on, small crank pulley and smaller than oem power steering pulley. Not a massive issue, just need to blip throttle when reverse parking.
    Otherwise. It’s pretty tight, gone through some local twisties with more than normal comfort pace and it didn’t step out/understeer at all. Pretty keen to see how it goes on a track!
  7. #147
    nsw
    Was it 8kg/mm fronts and 10kg/mm rears you went with? Have you stuck with them or gone to different rates in the end?
  8. #148
    Jun 2011
    7kg/11kg - Front/Rear
    Front bar on stiff, rear bar on soft.
  9. #149
    nsw
    Pretty rough on the street or not as bad as you'd think?
  10. #150
    Jun 2011
    It’s good actually, better than the FK’s, despite having twice the spring rate in the back.
    Doesn’t have that harsh impact when hitting bumps like most coilovers I have experienced which is nice.
