Page 11 of 21 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 205
Thread: Hayden and Cliffos Mk4 R32 build
  1. #101
    After 3.5 months, wheels finally turned up and thankfully clear without spacers! YAY
    17x8 ET30 Team Dynamics Pro Race 1.2’s
    While not the lightest wheel around, they are the only ones that will clear without massive spacers I’ve been able to find.
    They'd look good on my vento or your mk3..
  2. #102
    Jun 2011
    The thought of putting mk3 size rubber on did cross my mind. But to late now.
  3. #103
    Aug 2006
    Melbourne VIC
    Not a fan of all those holes in the rad support.
    My old man will be onto you!
  4. #104
    Jun 2011
    Quote Originally Posted by Water Boy View Post
    Untouched around the radiator itself so shouldn’t effect air flow through the core.
  5. #105
    Jun 2011
    Got the header finalised today, v band tested and welded on so the front of the car can go back together.
    Lick of paint to start.
    Wrapped up for some heat management.
    And then covered up, never to be seen again
    Opted for the MK5 heatshield as it is substantially bigger than the MK4 and will keep the heat out of the top half of the engine bay, and more importantly away from the brake master cylinder which is awfully close.
  6. #106
    Apr 2014
    Penrith, NSW
    Nice work brother, looks mint! Good tip on the Mk5 shield.
  7. #107
    Jun 2011
    Getting closer to finishing the car so put the new discs on the front and cleaned up seam sealer.
    Reassembled the front end and bled the brakes. Having a few issues with one of the rear calipers. Hopefully get that sorted out sometime soon.
  8. #108
    brisbane
    May 2019
    Devonport Tasmania
    Are they 6 pot Brembos
  10. #110
    Jun 2011
    Quote Originally Posted by guile View Post
    looks like a serious bit of kit, nice work...
    Thanks man. Hopefully works well!
