Page 5 of 21 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 205
Thread: Hayden and Cliffos Mk4 R32 build
  1. #41
    Jul 2017
    Hackett, ACT
    Great thread. Can't wait to see the finished product!
  2. #42
    May 2009
    North Brisvages
    Did you notice any braking improvement after fitting the Willwood setup ?
  3. #43
    Jun 2011
    Quote Originally Posted by Big_M View Post
    Astronomical improvement.
    Stops from 100 on a dime.
    Sent from my Moto C using Tapatalk
  4. #44
    May 2009
    North Brisvages
    Wow, sounds like a worthwhile upgrade, Were they expensive ?
    The rears just standard or you changed those too. Any braking bias change noticed.
  5. #45
    May 2014
    Newcastle, Australia
    Work out to be about 1300 delivered
    Sent from my Pixel XL using Tapatalk
  6. #46
    May 2009
    North Brisvages
    True.
    Did you grab yours of Chester ? I see he had some up for grabs earlier in the year.
  7. #47
    Jun 2011
    True.
    Rear gets a little light, but it's got 2 front seats and nothing else inside.
    From the man himself.
  8. #48
    Jun 2011
    So after many many many moons.
    Finally got CTS engine mounts.
    Quick hit down the street and no more driveshaft on subframe action!
    Hopefully the coupling didn't cop to much abuse. It's been sitting since Nationals waiting for the Engine Mounts, now we can have some fun.
    Although thermo fans are still broken and thermostat housing leaks..
  9. #49
    Eastern suburbs of Melb
    I also have some radial 4 pot front mounts, bias is off but you get used to it just before you go through the windscreen they work well.
    Good job boys!!!
  10. #50
    Jun 2011
    It’s still alive, been a daily driver for the last ~8 months or so.
    Started getting it ready for the VW nationals a couple weeks out, change coilovers, remove airbags and sound deadening, APR intake, brake flush, finally wire up thermo fans, fix the leaking thermostat housing, replace the crack pipe and fit two sparco seats and rails I found on eBay one night!
    Dirty fluid
    Only photo of the seats
    Associated fan wiring I was able to remove
    Slim fans and removed oem shroud
    Get to two days before, the finally fixed thermostat housing had caused the water pump to be the next weak linkHayden and Cliffos Mk4 R32 build
    Fortunately I had a new metal impeller pump sitting at home from my MK3 dream days.
    Made it to the track and had an absolute blast.
    Clutch was slipping prior but only in 4th, 5th and 6th thankfully never needed to be in the low/mid rpm range in the gears to make it be an issue.
    New clutch and LSD on the way for the next round of fun.
