Page 4 of 21 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 205
Thread: Hayden and Cliffos Mk4 R32 build
  1. #31
    Aug 2006
    Melbourne VIC
    Looking forward to the next round of updates!
  2. #32
    Nov 2006
    Largs Bay, S.A.
    Put centre console back in, drop it down to go for a test drive. Car doesn't start. Code reading, unplug and replug a bunch of stuff.
    Found out car won't start when cigarette lighter is plugged in..
    Is that some home-made security feature or just a weird coding error?
  3. #33
    May 2014
    Newcastle, Australia
    Quote Originally Posted by RolfGolf View Post
    We think it is something to do with the dodgy wotbox install, definitely going to have to remove or fix it up asap.
    Sent from my Pixel XL using Tapatalk
  4. #34
    Jun 2011
    It drives!
    Passed pink slip today.
    Time for some fun
  5. #35
    Aug 2006
    Melbourne VIC
    Quote Originally Posted by cliftronix View Post
    Remove the ****!
  6. #36
    May 2014
    Quote Originally Posted by Water Boy View Post
    Remove the ****!
    As soon as we find a new ignition loom it will be sooo gone.
  7. #37
    Jun 2011
    Pffftt.
    Mangmangmangmang
    Has some weird issue where it will just continuously crank and never fire. But only intermittently.
    So have a few more things to do yet.
    Clt temp.
    Or crank sensor.
  8. #38
    Jun 2011
    Drove it down to Nationals and around the hell hole known as "Sydney"
    Was going well till hit traffic. Thermo fans don't work, so sweated out with the heater on for a bit.
    Engine mounts/ cliffo's cross thread mod on the dogbone mount has caused some hectic movement to the point of tailshaft grinding on the subframe.
    It rolled over to 27000km's too......
    Only photo from the weekend.
  9. #39
    May 2014
    I will debate that the cross thread mod was already installed before i got there.
  10. #40
    May 2014
    In updates:
    New Coolant Temp Sensor
    Adjustable control arms in
    Coilovers installed, powerflex bushings
    Wilwood front brakes with lines, would have photo of weight of stock brakes but they tipped the 5kg scales by alot.
    Still waiting on engine mounts
