Great thread. Can't wait to see the finished product!
Printable View
Did you notice any braking improvement after fitting the Willwood setup ?
True.
Did you grab yours of Chester ? I see he had some up for grabs earlier in the year.
So after many many many moons.
Finally got CTS engine mounts.
http://www.vwwatercooled.com.au/foru...398992d4-1.jpg
http://www.vwwatercooled.com.au/foru...456de3f8-1.jpg
Quick hit down the street and no more driveshaft on subframe action!
Hopefully the coupling didn't cop to much abuse. It's been sitting since Nationals waiting for the Engine Mounts, now we can have some fun.
Although thermo fans are still broken and thermostat housing leaks..
It’s still alive, been a daily driver for the last ~8 months or so.
Started getting it ready for the VW nationals a couple weeks out, change coilovers, remove airbags and sound deadening, APR intake, brake flush, finally wire up thermo fans, fix the leaking thermostat housing, replace the crack pipe and fit two sparco seats and rails I found on eBay one night!
Dirty fluid
https://uploads.tapatalk-cdn.com/201...e665e6c6ef.jpg
Only photo of the seats
https://uploads.tapatalk-cdn.com/201...66bd1860d9.jpg
https://uploads.tapatalk-cdn.com/201...5093e6cc2c.jpg
https://uploads.tapatalk-cdn.com/201...d5dfedb4d1.jpg
Associated fan wiring I was able to remove
https://uploads.tapatalk-cdn.com/201...5a2aa6c36b.jpg
Slim fans and removed oem shroud
https://uploads.tapatalk-cdn.com/201...68ab7793a7.jpg
https://uploads.tapatalk-cdn.com/201...7e11e1501e.jpg
Get to two days before, the finally fixed thermostat housing had caused the water pump to be the next weak link[emoji20]
Fortunately I had a new metal impeller pump sitting at home from my MK3 dream days.
https://uploads.tapatalk-cdn.com/201...fdfcadbeef.jpg
https://uploads.tapatalk-cdn.com/201...2444b1ca63.jpg
Made it to the track and had an absolute blast.
https://uploads.tapatalk-cdn.com/201...d73d77c08b.jpg
https://uploads.tapatalk-cdn.com/201...3303082bb4.jpg
Clutch was slipping prior but only in 4th, 5th and 6th thankfully never needed to be in the low/mid rpm range in the gears to make it be an issue.
New clutch and LSD on the way for the next round of fun.
