Page 3 of 21 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 205
Thread: Hayden and Cliffos Mk4 R32 build
  1. #21
    May 2014
    Newcastle, Australia
    Powerflex dogbone inserts
    Sent from my Pixel XL using Tapatalk
  2. #22
    May 2014
    Engine in, wired up. Just need new plugs in and fluids.
  3. #23
    Jun 2011
    Needs more mk3.
    The DMF was so rooted that it could be spun 20mm+ side to side, once the pressure plate was removed, ball bearings and springs fell out!
    Not as difficult as a process as it looks, vw definitely took a step backwards with these cars compared to the Mk3 VR6
  4. #24
    This guy! hahaha
    Good work guys!
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  5. #25
    Jan 2010
    Melb Westsideeeee
    Good work doods. When is the interior coming out? Full strip? Cut the door skins off, remove p/s for a more 'real' feel hahaha
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
  6. #26
    May 2014
    Quote Originally Posted by GeorgeMK1 View Post
    Just going to remove all the airbags and unnecessary stuff for now , sound deadening etc and maybe some speakers. Carpet might be going back in!
    Got it all back together to find that all the exhaust manifold gaskets are done, new ones on the way!
  7. #27
    Eastern suburbs of Melb
    Sell me the front bar before cliffo rams into a poll with it...
  8. #28
    Quote Originally Posted by thestu View Post
    Too soon?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  9. #29
    Jun 2011
    Flat out few weekends, finally had some time to go to work.
    Torque'd to spec as cliffo forgot the only tool he needed to bring.
    Everything was running pretty smoothly. Got the car running, rough as guts again, but no exhaust leaks so a win on that hand.
    Whilst running it blew a coilpack out. Like physically out of the head. Decide to pull all of them and plugs. Check what's going on, tighten and turn it over again.
    Get to the last plug and it just keeps free spinning.
    Whoops.
    Managed to get it out with a screwdriver as it was still loose.
    None in stock around here. So wait for dealership tomorrow. Hopefully.
  10. #30
    Jun 2011
    Got an oem plug. Torqued it down to avoid another breakage.
    Torque down the others and free spinning again!
    Another one let go. Surely a bad batch, this was done by hand.
    Back into the dealership to get another plug.
    Put in new coilpacks to be certain. Removed some extra vac hose and resealed the dodgy pcv hoses.
    Turn it over, fires first crank and idles perfect.
    Put centre console back in, drop it down to go for a test drive. Car doesn't start. Code reading, unplug and replug a bunch of stuff.
    Found out car won't start when cigarette lighter is plugged in..
