Page 12 of 21 FirstFirst ... 21011121314 ... LastLast
Results 111 to 120 of 205
Thread: Hayden and Cliffos Mk4 R32 build
  1. #111
    Jun 2011
    Quote Originally Posted by Thomasmk3 View Post
    Are they 6 pot Brembos
    Correct. They are the 17z calipers, EBC bluestuff pads and DBA rotors
  2. #112
    May 2019
    Devonport Tasmania
    Oh yeah sick, I still need to find decent rotors for my 18z’s for my Audi
  3. #113
    Jun 2011
    A combination of big calipers and new sway bar location meant that I couldn’t get my old brake tubing to fit anymore.
    While trying to find scoop idea’s to make one up. I came across these RS3 brake ducts. Seem to be a popular mod for MK7 people.
    Found an Aussie seller and got a pair for not a lot of money.
    Fit onto the control arm ok. Takes a bit of force to move them so should be rated to the top speed of this thing..
    Also chucked a seat back in on the new seat base. Heaps lower than the other bases which is always nice. The seatbelt mount is way to high up though. So will need to look at another buckle for street duties
    New seat base
    Old seat base
  4. #114
    Aug 2006
    Melbourne VIC
    Honda civic seat belt buckle are short and easy to obtain (Ill snag you one at the wreckers)
    I think a nice motorsport steering wheel should be next!
  5. #115
    Jan 2011
    Gold Coast, QLD
    New seat base
    Old seat base
    What do the air ducts connect too?
    Sent from my LG-H870DS using Tapatalk
  6. #116
    Jun 2011
    Quote Originally Posted by Water Boy View Post
    Yeah sweet thanks woody. Would need the buckle to be around 50mm long to be ideal. Also with a seatbelt light harness.
    Re: steering wheel, I was able to remove all of the airbag stuff so it now weighs as much an aftermarket wheel, but looks oem!
  7. #117
    Jun 2011
    Quote Originally Posted by Sirocco20348 View Post
    Line up with the big side bumper vents so will scoop air in from them.
    I mocked up feeding air directly to them with my old tubes and could sort of make it work. But will see how these go to start with.
  8. #118
    Jun 2011
    Having an issue getting the car started.
    Has 5-6v drop when cranking. Tried two other batteries that start other cars with no issue. Only way I can get it to start is with a fresh charged battery once, or with 2 batteries in parallel, even then it struggles and gets to as low as 7v.
    I’ve tried new positive and negative leads, even real short ones, checked the solenoid wire from ignition switch, bench tested starter motor and it uses 1v unloaded. Not sure if this is a normal value??
    After i get it started and use the alternator to charge the battery for 20-30 minutes then try re-start the car immediately it still fails to start it again.
    I’m confident the batteries are ok as they start other cars. The leads are ok, the trigger wire from ignition switch to starter is ok and the starter is ok.
    I recall having an issue initially with the car and the cigarette lighter causing a crank no start as well as the temp sensor, but that is unplugged and the temp sensor is new.
    I’ve removed the rear speaker wiring and the air bag wiring from the car. Which has nothing to do with the starting circuit. So I’m not sure what to do.
    HELP??
  9. #119
    Jun 2011
    So after charging my battery day after day. Turns out my charger that previously has been ok, was not ok this time round.
    Took it back to the shop I purchased it from, they charged it up over night and car starts as it should again.
    VCDS bled the brakes and they are still crap, soft pedal. Firm when engine is off. And pedal sinks an inch when car is turned on. So I’m confident that the booster is sealed and the master is working good.
    Have put 1 litre of fluid through the system. 500ml gravity bleeding and another 500ml pressure bleeding. Going to get an oil can tomorrow and try reverse bleed.
    Chucked the wheels on and got it off the jack stands. Sits super high. So need to adjust that a bit.
    Seem to have very little negative camber in the front. Even with the ball joints and camber tops maxed which is disappointing. Wish I saved the money on the camber tops and just got control arms instead.
  10. #120
    Jan 2011
    Gold Coast, QLD
    Hey mate, can you please tell me more about the following..
    With the 26mm master cylinder, is that meant to increase the pressure applied to the brakes?
    What is the 26mm measurement referring to?
    And what was the size of the stock master cylinder? And why didn't you go with a stock master instead?
    Just curious as I'm sure my master cylinder will fail eventually.
