Results 1 to 7 of 7
Thread: Have I broken an engine mount?
    Jul 2010
    Elanora Heights, Sydney
    So, I haven't had much time to try and work out what I've done, but I have started getting a little bit of a knock from the front end over bumps.
    Last year my sway bar link came undone and was knocking on some bumps, its a similar noise, so I jacked the car up on Monday arvo and gave the sway bar link a good push and shove, nothing. But, when I turned the wheel against the gearbox (ie, just turned it while it was jacked up as much as I could) I noticed the engine moved (rotated) slightly front and back. Now, I can't be certain, but it seemed to move more than it has in the past and I wasn't giving the wheel a hard time, it was just a leisurely rotate.
    I can get under and check the dogbone - I did replace that last year. Its a similar kind of rotation as when the dogbone was out. But, what else can I check?
    Thanks guys,
    Christian
    Jul 2009
    Geelong, Victoria
    engine mount sounds right.
    However, CV joints can make knocking sounds when they are gone too. Check for split boots for starters
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
    Jul 2010
    Yeah it's not the clicking of a cv and no worse when turning. So don't think it's that. Will crawl under the car and check dogbone.
    Northern Beaches
    Thought my front left shock was blown, end up being my dogbone mount.
    the round bush was leaking oil. it's the second 1 ive installed.
    Apr 2006
    VW Race HQ - Sydney
    Quote Originally Posted by VDUB-BUD View Post
    The bush doesnt hold oil , thats either gearbox oil or engine oil thats leaking !
    Bug_racer supports the rebellion of the euro revolution
    Jul 2010
    Check where that oil is coming from.
    I still have my old dogbone and bush (new one has only been in for 2000k's or so) so I can switch them over if needed.
    Apr 2006
    VW Race HQ - Sydney
    Quote Originally Posted by PranK View Post
    Thanks guys,
    Christian
    Change your sway bar bushes
