engine mount sounds right.
However, CV joints can make knocking sounds when they are gone too. Check for split boots for starters
So, I haven't had much time to try and work out what I've done, but I have started getting a little bit of a knock from the front end over bumps.
Last year my sway bar link came undone and was knocking on some bumps, its a similar noise, so I jacked the car up on Monday arvo and gave the sway bar link a good push and shove, nothing. But, when I turned the wheel against the gearbox (ie, just turned it while it was jacked up as much as I could) I noticed the engine moved (rotated) slightly front and back. Now, I can't be certain, but it seemed to move more than it has in the past and I wasn't giving the wheel a hard time, it was just a leisurely rotate.
I can get under and check the dogbone - I did replace that last year. Its a similar kind of rotation as when the dogbone was out. But, what else can I check?
Thanks guys,
Christian
Yeah it's not the clicking of a cv and no worse when turning. So don't think it's that. Will crawl under the car and check dogbone.
Thought my front left shock was blown, end up being my dogbone mount.
the round bush was leaking oil. it's the second 1 ive installed.
