Originally Posted by
ntails
Alarm looks to be installed well as it was already in the car when i purchased it.
Running two amps but they have been in there a while before the issues started.
Funnily enough the alarm hasn't played up for the last couple of days....no doutb it will start again when i really don't want it to.
Because a car alarm did not cuase issue's when you bought the car does not mean that it's not the cause.
I have a friend with a corrado over here. He had an alarm fitted to it.
It started causing issue's around 4 months ago. Now the alarm has been in the car for around 3+ years.
Sometimes the unit's fail. His battery kept going flat which was caused by the alarm.
Hopefully this helps and points you in the right direction.
Audi S4 (2001) - Imola Yellow
Secret Project
