Quote:
No offence... but have you ridden a street bike? they have bugger all torque too, but they rev to 16k. That's how they make power. Problem with an engine that doesn't flow is that it doesn't make power low, nor at high rpm either. Pretty sure the 2L trails off after about 5k rpm. As far as honda engines go (based on info i got a few years ago, and from top of my head), they run backwards, and they use different ratios of stroke and bore to all other manufacturers, and they manage to pull it off. I think there was an article about how, for their stroke length, the motors shouldn't need to/be revving that high.
Yep, I've ridden street bikes (albeit as a passenger, I don't have a bike license), and I'm well aware of the fact that they rev to around 16k. The problem with them though is that they suffer from lack of power and torque down low (but get away with it due to their light weight - 300kgs or so with a rider and a tank of fuel for a Hayabusa for instance, but they produce somewhere around 120kW at the rear wheel, meaning you end up with something like 350kW/tonne.
Quote:
A well designed engine with more cams has more control, as individual valve movements can be determined. But that'd start the topic of valve timing, and different timing at different engine loads, hence the need for mivec, vtec, vvti, etc.
fundamentals:
flow = power.
sohc flow < DOHC flow.
I think it's more accurate to say
