Results 1 to 9 of 9
Thread: Hard steering at low speeds on the 4mo. Problem?
    Oct 2013
    Eastern Melbourne
    Gday all,
    Fellow 4mo owners - do you find your steering hard and heavy in general? I find my car is a lot harder to turn than most vehicles I've driven. I've got no noises but it's definitely a bit of a challenge to turn the car at low speeds - especially parking.
    Now it is lowered and has 8.5" wheels so I'm wondering is that to blame?
    Should I look into this?
    If so, I've checked fluid level and it's topped up fine. Tie-rod ends have been replaced less than 1000km ago.
    Looking at the other power steering parts - i.e. lines, pump, belt, pulley - they do look a bit a worn. Belt is not cracked but used. Line looks worn out. Pump pulley seems to rotate wonky.
    Do I need a new pump, line, or anything else? Best way to diagnose?
    Appreciate any help here.
    Quote Originally Posted by MightyCarMods
    I'd rather lose by a mile because I built my own car, than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book.
    -| "Laura" - 2001 Bora 4-motion (now sold) |-
    Dec 2008
    Sydney/Canberra
    Do the rear wheels skip or chirp at low speeds?
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Oct 2013
    Eastern Melbourne
    Quote Originally Posted by Umai Naa!! View Post
    Newp. Not that I remember. I'll drive it today and test but I don't think my haldex is stuffed. She has had a recent oil change thankfully.
    Dec 2008
    Sydney/Canberra
    How wonky is the pulley? Is it only a tiny bit, or is it way out?
    Also check your tyre pressures, and maybe consider doing a fluid flush of the power steering. Oil should either be gold or dark green. Make sure you use a fully synthetic power steering oil to flush it.
    '01 Beetle 2.0
    I have fairly heavy steering but I'm preety sure it comes down to the weight of your rims I upgraded mine to Aristos which are still heavy but a bit litter then the stock bora 16s and found it was a bit easier to turn.....then I tried my mates oz superturismos and my steering was effortless
    Dec 2008
    Sydney/Canberra
    Tyre pressures play a big part in it too.
    '01 Beetle 2.0
    Oct 2013
    Eastern Melbourne
    Hard to answer. Personally I think any wonky pulley is a bad pulley? I'll see if I can get a video of it.
    Tyre pressures are around 40psi on my 225/40r18 tyres that are stretched over a 8.5" rim.
    I will do a power steering flush though. Good advice! Oil is currently a darker shade of gold.
    Quote Originally Posted by semiroundmark View Post
    Interesting sentiments! Thanks! I've got Miro Type 111's which are not lightweight wheels but seemed to be no heavier than my stock 16's.
    How hard is hard? (that's what she said!)
    My car's steering is so hard at low speeds that it feels like it has no power steering. I've driven at least 15 different cars and none had this hard steering.
    What do you think of 40psi? I'll maybe consider dropping it to 36psi.
    Dec 2008
    Sydney/Canberra
    40 is fine. 36 will make it worse.
    '01 Beetle 2.0
    Oct 2013
    Eastern Melbourne
    Do you think the stretched tyres could have something to do with the hard steering feeling?
    I must say that I struggle to get grip down with my setup and she's quite unsettled at high speeds through corners. I have practically new Pirelli P7s on her.
