Results 1 to 5 of 5
Thread: hard 2 select 3rd n 5th gear
    Aug 2006
    iv been reading vortex and they say it could be gearbox mounts and 'dogbone' mount..
    has any1 had a issue like this?
    Apr 2008
    They're possible reasons, yes. As the mounts fail, the gearbox sits in a slightly different position in relation to the gear selection mechanism which is mounted on the chassis. There's a small amount of adjustment possible with the gearbox selector mechanism where it connects to the shift selector on the gearbox, it may be possible to account for the gearbox droop, but ideally, if the mounts are gone, it'd be worth getting them fixed.
    Quote Originally Posted by BL33SU View Post
    Nothing to see here...
    Aug 2006
    thanks for the info..
    is it called gearbox mount? or is the dogbone mount the same thing...
    Apr 2008
    There are three mounts:
    * Gearbox mount on the left of the engine/gearbox combination.
    * Engine mount on the right of the engine/gearbox combination.
    * Dogbone mount underneath the engine/gearbox combination which connects the engine/gearbox combination (underneath it) to the chassis behind it.
    May 2010
    Perth
    Try doing the cable adjustment for your shifter that may help, could also be a bent selector fork inside the gearbox, hopefully its not though, or the mounts.. If it is the mounts, i recommend replacing all three at the same time.
    YouTube - Volkswagen Group Shift Linkage Adjustment for year models 2000-2010
    Cheers Pedro
    '76 Mk1 LS
    '04 Mk4 .:R32
    '09 Audi S5
