Results 1 to 10 of 10
Thread: Haldex Fuse?
    May 2010
    Perth
    Haldex Fuse?
    Which fuse is it to disable the haldex on a bora 4mo?
    Want to run the car on a 2wd dyno and want to make sure its properly disabled for obvious reasons...
    Current: '04 Astra SRI Turbo - EDS IPF Flash, 3" TBE, Quaife LSD
    Previously: Bora 4mo, cams, coilovers, tune, exhaust, brembo's etc
    It should tell you in the owners manual and inside the fuse box lid.
    Don't forget VCDS to reset the fault codes.
    May 2010
    Perth
    VCDS?
    showing my VW noobness!
    Apr 2008
    VCDS is another name for VAG-COM.
    Pull the ABS fuse to disable the Haldex, as the Haldex relies on signal from the ABS system to determine slip and thus when it should be engaged.
    Nothing to see here...
    May 2010
    Perth
    even with an aftermarket haldex controller?
    Apparently my ECU cant be read (possibly due to an issue with the car stereo), so I guess I wont be able to have fault codes reset either
    Apr 2008
    By aftermarket Haldex, do you mean blue/orange?
    They still take their signal from the ABS circuit.
    Aug 2007
    Perth, Australia
    i wouldnt play with it mate. you wouldnt wanna burn the system. If you need to reset the codes PM me, i have the V-Checker
    1991 BMW 318is RED E30
    May 2010
    Perth
    yeah, 4wd dyno it is, interesting to see how the haldex works on the dyno haha
    Dec 2007
    Brisbane, Southside...
    You can run on a 2WD dyno without any issues no worries. Plenty of people have done it including myself with no dramas. You won't burn anything out. All that will happen is that you will get the traction control light come up. The system doesn't even throw a fault that needs to be reset. Once you plug the fuse back in all is good. You can also run on a 4WD dyno without any issues as well. You will have approximately 30% drivetrain loss in 4WD mode and of course slightly less in 2WD mode but not as good as a normal FWD car.
    Fuse 31 is the Haldex fuse on the R32, Audi TT and I'd wager money on it being the same on the Bora V6 4motion as well. It should be the only 5A fuse in the lower section which contains the larger fuses (larger in physical size that is).
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Nov 2006
    Brisbane Qld
    And you just need to mirror image Trents pic for RHD fusebox locations.
