Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 56
Thread: Hairy_mic's V5 Bora
    Quote Originally Posted by Hairy_mic View Post
    Have to be moved back 10mm to sit flush need to get the dremel into the plastic cage
    realised why this has never sat flush on mine, wiring comes out of the headunit right at support.
    think ill get away with just cutting parts of it.
    Just my imo, that bumper looks rubbish... get a Rline, R32 rep or something else OEM (new valance). or stay factory, not like the front looks bad as is
    Mar 2013
    Update.
    OK so eventually got donor car home last weekend.
    Gonna start stripping it tomorrow.
    Bought a box of Stinger expert sound deadening
    http://t1.gstatic.com/images?q=tbn:A...kZTRcO4kDN9l5A
    Have been looking about for a repair manual. got a UK haynes manual coming from ebay, but it unfortunately it doesnt cover my engine. 2.3 l V5 20V AQN
    Spent a few week looking for a manual or something to no avail. Somebody on another forum (VW employee (or at least had access to)) hada pdf of the VW AGZ 10v engine.
    So looking like a 20v manual doesnt exist??
    I found what looks like a VW training manual for the AGZ. It is actually quite interesting and worth a look.
    http://www.volkspage.net/technik/ssp/ssp/SSP_195.pdf
    Quick question for anybody that can answer...
    I understand that the v6 4M will have a different drivetrain and suspension parts to the V5, but as V5 doesnt show up on ECS so should i chose 1.8 T / 2L etc??? ( so i get the right bushes for my suspension etc)
    2004 VW Bora v5 Auto
    Hairy_mic' custom audio build http://www.vwwatercooled.com.au/foru...ent-85117.html
    Mar 2013
    I closed the subthread re my engine fault,
    Thanks JedR32 think your spot on with the coils.
    Sparking on 1 2 4 5
    no spark. on cyl3 new plug, still no spark.
    3+4 look a quite a bit different to the rest
    Hairy_mic's V5 Bora-d272eb60-5814-47fd-9406-54b945a55320-182-000000093d2e9503_zpsa7e7df9d-jpg
    Hairy_mic's V5 Bora-bc7ab773-8048-4b7a-b8ee-484282d70af1-182-0000000958aa8c06_zps9b6707fe-jpg
    plugs 2 3 4 5
    Hairy_mic's V5 Bora-127243ec-9696-4ddc-bcdc-fac47b716eba-182-0000000966a07c2c_zps78f26d47-jpg
    2 3 4 5
    Hairy_mic's V5 Bora-04b16100-685d-4725-8166-5cd2483078dd-182-00000009494f2b7d_zps4a4b03e1-jpg
    from the bottom coils 3 and 4
    Hairy_mic's V5 Bora-d09497b4-3ed6-4d8a-8fe3-06cb32c7bc6d-182-0000000975fcbbf5_zpsea5ca6a7-jpg
    Pretty much confirmed that it is a coil. i think.
    Need 1 of these now i should probably replace 3 and 4 but 3 at the very least. (money tight at the mo)
    with the intention of replacing with a full set eventually.
    too cheap ? http://www.ebay.com.au/itm/Tesla-Ign...3bb50d4&_uhb=1
    Still too cheap ? http://www.ebay.com.au/itm/Meat-Dori...61250306260%26
    any better? http://www.ebay.com.au/itm/Quinton-H...3b9cd53&_uhb=1
    I need this part yesterday, ill need to order one tonight..
    Jul 2007
    Brissy
    Have you swapped the coils around just to confirm it is the coil, and not a problem getting signal to the coil ?
    The V5 looks different, but for what it is worth the 1.8T has a module which signals each coil to fire. When this goes it appears that a coil is dead but is not.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Mar 2013
    Hmm no, I didn't check that. Tbh though based on the overall condition of the coil I am pretty sure it's that. If there is a controller that's gubbed them I'm not gonna be happy
    Mar 2013
    Ok.
    So as I couldn't afford a full coil pack replacement. Bought 2 which arrived yesterday. Swapped cyl 3. Engine better, but not quite right. Checked engine codes, cyl 1 misfire. So swapped that one as well. Thought it was weird as I had a confirmed spark when it first blow coil 3. Engine started good, went for a run. Car was great.
    Until I went to the shops later.
    Same **** misfire thou this time coil 2.
    Would the introduction of 2 newer coils affect the others?
    I'm going to order a further 5 tonight,
    Does anybody know how to test the function if the coil and the connector, I have a multimeter.
    so frustrating. Just worried it may be something other than the coils.
    Thanks folks
    Mar 2012
    Brisbane, Queensland
    This could be a combination of coils and something else. Possibly controller, possibly spark plugs. I'm not an expert but I'd head to your local VW mechanic to get it diagnosed. Where are you located?
    No. 164 - HPA Competition Haldex Controller, KW V3's, Southbend Stage 2 Singlemass Flywheel, Simota Racing Air Intake
    Mar 2013
    Orange nsw. We have a vw dealer here, but that's gonna cost me a fortune
    Mar 2013
    Update.
    Ok so I changed 2 of the coils, sorted. Gonna get a full set from ECS, but wondered if anybody else is ordering soon we could save postage
    Ordered all the oil I need to redo my trans and engine oil. Also for filters fur engine and trans, and some gasket sealant for less money than my local dealership wanted for the trans
    Used tooleys imports in sydney I'm very impressed do far
    Mar 2013
    Wiring in my rearview camera, cant work out one thing.. the yellow AV cable has a red cable attached,
    The camera has a power jack (which i connect to the rev light) i just dont understand whats it for,
    The instructions are in chinglish and the diagram sux ass anyh ideas>
