Results 1 to 10 of 15
Thread: GTI Suspension different to standard golf ????
    Nov 2013
    Goldcoast QLD
    hey all as the title says , is the GTI suspension different to a standard model golf ??? mainly sway bars and springs ??? if so how and can you fit it to a standard golf ?
    any information would be great
    thanks
    size of sway bars are the same I believe, layout is the same.
    springs in the gti are 15mm lower or so, not sure if the struts are the same length/damping.
    but yes, bolt in exactly the same.
    basically all the mk4s are the same, and can swap tons of stuff like you mention.
    its only different when you get from FWD to AWD cars, even then SOME things can be swapped in without too many issues
    Nov 2013
    Goldcoast QLD
    Perfect thats pretty much what I needed to know , is the spring rate different in the gti And are they worth putting in my standed golf with some good shocks ??
    not sure about spring rates, I imagine a bit firmer.
    if you can get them for free/cheap yeah sure.
    other wise go down the path of eibach/h&R springs or coils for a 30-50mm drop
    iv seen people put a low km set of gti springs in a highish km standard mk4, and the car actually got higher due to the original springs having sagged so much and the gti springs being still fresh and perky.
    this can also apply to the 30-50mm drop springs I mentioned, you might only get a 15mm drop or so out of them if your stock springs have sagged so much.
    mk4s had a STUPID amount of wheel gap from stock on super soft springs
    Nov 2013
    Goldcoast QLD
    ok then thanks for that , i think i might just buy some after market springs and some good shocks, i dont wanna lower it much as my sump all ready scrapes on just about every speed bump i go over with and its all factory suspension with 150xxx k's on it
    i was going to go coilovers but it is my daily driver after all and i dont think i really need them
    in a 1.6/1.8/2.0 your sump shouldnt be touching the road regardless of how low you are. subframe and dog bone mount hang much lower.
    Cup kit should ride nice
    Nov 2013
    Goldcoast QLD
    hmm its prob something else scraping , but my sump has a few good marks on it , sorry if this sounds like a a dumb question but what do you mean by " cup kit " ? i was going to get some bilstein shock and a good set of low springs
    Feb 2009
    Please Enter Location
    You obviously haven't got on your hands and knees and had a look ???????
    VW probably sold more G4 sumps than any part for that model.
    Go ask your insurance company.
    I'd get a sump guard first.
    Nov 2013
    Goldcoast QLD
    Quote Originally Posted by Stanton View Post
    where would i get a sump guard from , im still new to euro cars
    Quote Originally Posted by aaron001au View Post
    yeah cup kit is a spring and shock combo sorry.
    every mk4 iv looked under (other then VR) it sits higher.
    my own car included, hence why iv never bother bothered with a sump guard even when the car is basically touching the ground.
    sure if you hit an awkward shaped bump you could get it up to the sump, but thats not going to happen often
