size of sway bars are the same I believe, layout is the same.
springs in the gti are 15mm lower or so, not sure if the struts are the same length/damping.
but yes, bolt in exactly the same.
basically all the mk4s are the same, and can swap tons of stuff like you mention.
its only different when you get from FWD to AWD cars, even then SOME things can be swapped in without too many issues
