GTI shutting down during normal driving
Hey guys,
My GTI ran into some trouble, its still stock at the moment, I was driving locally when the car seemed to hesitate and then completely shut down. I called the NRMA but after half an hour of waiting I decided to give it another whirl and it started.
I thought maybe there was a bit of a hickup in the fueling but couldnt find any codes and it drove normally for a month, then I was driving on the highway the other week and happened over again. The engine stumbles for a second, and then shuts down completely. This time I decided to give it a go every 10 mins to see what happened and after about 40 mins it started again and drove home without a hitch.
I took it my mechanic and he couldn't find any obvious issues and suggested the fuel pump as the most likely culprit given it's tendancy to come back to life. Fuel pump swapped and test driven for 40 mins with no issue, then I went and drove it for about 30 mins an hour later and the same issue. I was in a precarious spot so I called for a tow straight away but it still wasn't starting when it got picked up so it's possible whatever it was died completely, but I get the feeling it will start when it gets looked at tomorrow.
My best description of the circumstances and symptoms are;
- Happens at normal operating temperature
- Usually happens after a bit of driving even in one stint of if the engine hasn't cooled between drives
- Issue seems to usually occur under load and part throttle, most of the time I've been going up a gradual incline.
- The car will drive normally up until the issue arises usually no prior indication that something is going wrong
- The car stumbles/bucks before shutdown maybe misfiring on one or more cylinders (kind of the feeling you get when an auto can't decide on a gear)
- Starter motor turns over fine afterward
- Engine doesn't pick up at all afterward
- After a while it might give a bit of a gurgle like its going to start but doesnt quite make it
- I noticed on the last shutdown the accelerator peddle moving slightly underfoot as the engine stumbled, a slight reduction in pressure and then a slight increase against my foot back and forth a few times.
- Pulled a coil off and had spark on cylinder one, car started before I checked the others
Car has now (syptoms have occured before and after all these changes);
A new fuel pump
NGK BKR7E with less than 1000km on them all properly gaped
replaced vacuum lines to the FPR and brake booster
Replaced thermostat and fully bled and replaced coolant, no signs of oil
Oil change <1000km ago, oil flowed well, no sludge, chunks or signs of coolant contamination
cleaned MAF with MAF cleaner, no obvious damage or corrosion
The oil leak issue from previous posts is still a mystery, degreased the engine bay and as yet haven't noticed any build up, though I'm yet to completely pull apart the intake system.
Is it possible for this car to vapor lock? its not exactly cool in the engine bay on a hot day even around the intake side. Other possibilities I'm looking at are maybe a crank position sensor? though I'm not sure it would be affected by temperature. or possibly a relay on it's way out?
Sorry for the wall of text, not sure where to go from here since I'm not getting any codes and so far all my mechanic and I can think of is replacing things until it's fixed, and since it's a pretty unpredictable problem it's hard to know if it is fixed.
Thanks!
- You may not post replies
- You may not edit your posts
Forum Rules
