just do it properly....bigger brakes means updating everything else to do with them![]()
so what did it cost you all up as my bf is interested in this mod?
After all said and done is it cheaper to get buy a BBK from the states or second hand?
Too much
I haven't added it all up but probably around the $2000 mark. I still haven't taken it through the mountains/anything that would warrant the larger brakes - Keen to get onto the track in the winter when the weather cools down.
Manaz - If your Bora currently has vented discs on the rear it will be a straight swap I believe. GTIs and A3s don't standard so the vented R32 discs are much thicker - Hence the spacers.
