Results 1 to 9 of 9
Thread: GTI loosing fuel pressure
    May 2012
    Coffs Harbour, NSW
    When I leave the gti overnight or for 6 or 7 hours, when it starts the revs go up as normal for 2-3 seconds then drop to 0.
    Start it again and it's fine. Does it everytime it's left. What clouds be causing it?
    Car has stage 2 custom code tune n exhaust. Rest is stock.
    Apr 2006
    VW Race HQ - Sydney
    Fuel pump is on its way . If a fuel pump cant hold pressure overnight its usually the seals inside that are going . To add to that the fuel pump should be primed when you open the door as well , so if you cant hear it when you open the drivers door you may need a new door lock ...
    Bug_racer supports the rebellion of the euro revolution
    Feb 2013
    Had this happen to my BMW. However, this was caused by a leak in my fuel line. Have a smell around the outside of your car to see if you can smell petrol.
    Good luck
    Jul 2011
    Agree with bug racer check if the pump primes when your Door is opened.
    Car will lose pressure over night this is normal nothing wrong with seal or pump.
    May 2012
    Coffs Harbour, NSW
    ah so it primes when the door is open. that's what it is then as my door sensor don't work. so it doesn't know and doesn't prime
    makes sense
    Sep 2009
    It should also prime when the ignition is turned on so next time just try turning the key to on and leaving it there for it to prime (will run the pump for a second or so) then turn all the way to start.
    Jul 2011
    Check if your interior light turn on when you open the drivers door it's the easiest give away which points to the lock being faulty.
    May 2012
    Coffs Harbour, NSW
    already know my drivers side lock is faulty, cause yes the interior light doesnt come on lol its annoying. guess ill start that today as well haha
    May 2012
    Coffs Harbour, NSW
    Ok, I can hear the pump prime when I turn the ignition on, doednt make any difference.
    What else to check?
