Results 1 to 7 of 7
Thread: GTI Fuel Filter
    Oct 2010
    northern beaches nsw
    GTI Fuel Filter
    Hi guys,
    do they ever need replacing?Also looking to do my 6 month service shortly and i,ve been using the one step colder NGK PFR7B 4853.Meant to last a couple of years I here but is there a preferred way to clean them up (used to soak them in petrol with my old cars) before screwing back in.Thanks
    Trent
    MK4 GTI Revo Stage 1 / BFI Dogbone Mounts / 710N DV
    Dec 2008
    Sydney/Canberra
    Fuel filter gets done every 60,000klms.
    It's located under the car, in front of the right rear wheel.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Yeah, IIRC it's not officially required to be replaced, but by all means do it if you think it needs it. There are some DIY vids for it on youtube, it's a straightforward job.
    Not sure about cleaning the plugs. If they're getting a buildup of black stuff, it probably means they're running a little too cold and you should go back up to the stock heat range. They should be running hot enough to be self-cleaning. If it's just that slight white powdery coating, I wouldn't bother cleaning that. It's normal and it'll be back again pretty much instantly anyway.
    Apr 2006
    VW Race HQ - Sydney
    Quote Originally Posted by Umai Naa!! View Post
    I do them every 30k km . Passats dont even have 1 !
    Bug_racer supports the rebellion of the euro revolution
    Apr 2006
    VW Race HQ - Sydney
    Quote Originally Posted by bloödstorm View Post
    Platinum plugs foul up a lot easier . Bad batch of fuel and you'll get a misfire and they are pretty much in the bin . I prefer copper core ones
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by Bug_racer View Post
    Petrol Passats and Tiguans do, but they're in tank. There's no service interval for them, though.
    '01 Beetle 2.0
    Apr 2006
    VW Race HQ - Sydney
    Thats like saying injectors have a filter on them too . Or the fuel pump itself . If it doesnt have a set interval its filtration properties will diminish over time and eventually get clogged up or stop working at all ......
