go to a slightly thicker viscosity oil if its really using oil.
My R does not use any oil at all. i think this has something to do with how the engine has been broken in when it was new
1991 BMW 318is RED E30
This ^
If the piston rings dont get seated properly from the very first start up your engine will always consume a little oil.
VW/Audi actually go by a quart of oil every 10,000KMs or a litre every 12000kms approximately, as being acceptable.
For engine break in procedures read this, it is a very good explanation as a how to.
Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power
'76 Mk1 LS
'04 Mk4 .:R32
'09 Audi S5
so glad i came across this posti had this problem months ago and was freaking out that something was really wrong since i wasnt leaking oil and my car was blowing no smoke at all. back when i posted up about it noone gave me any decent info about why it happens, at least now i know whats up now
i put slightly thicker oil in my car but i think ill go back to 5w or whatever its supposed to have and just top it up more oftern since i heard using the wrong oil can shorten engine life??
2.0 mk4 golf (SOLD)
mk1 76 4door ( long project)
Check engine oil light comes on WAY before you use ALL your oil ... - there would be a lot of seized engines otherwise. Your dipstick usually indicates a drop of up to a litre of oil - ie. meaning there's still oil in your sump, but you need to top it up.
When making the piston rings, a whole batch of piston rings had their labels "stamped" incorrectly. As a result of that, the piston rings were installed upside down when the engines were assembled. If you do a Google search you'll find much more info on the subject.
