Results 1 to 9 of 9
Thread: Golf Relay ticking when doing 100 km/h
    May 2011
    Melbourne, Vic
    Hi guys.
    So my 2.0L has a relay that is ticking when you are doing 100km/h for more then 5 minutes. Just wondering if anyone else has experienced this or would know what could cause it?
    Thanks,
    bruce93
    Jan 2012
    Epping, NSW
    Just look behind and see if Sandra Bullock and Keanu Reeves are in the back seat with worried looks about not dropping below 100.....
    Manual MY12 RB Golf R | Bluefin Stg2 | Milltek turbo-back
    Nov 2006
    Largs Bay, S.A.
    What relay is clicking? If it's the turn/hazard relay, it could be a problem with the contacts in the turn signal switch leaking voltage to the relay or the relay itself. There was a recall on the hazard switch on some cars for an improved version. Replacing the switch or disassembling it and treating it with contact cleaner might help. Do your indicators function as they should?
    May 2011
    Melbourne, Vic
    Hi RolfGolf.
    Thanks, for the reply.
    I'm not sure which relay it is that's the problem but yes my indicators do function as they should...
    Thanks,
    bruce93
    is it the same noise as if you had your indicator on or the hazards button?
    May 2011
    Melbourne, Vic
    No it's not the same noise as the indicators.
    Thanks,
    bruce93
    Jan 2012
    Epping, NSW
    Did you check your speed warning is set to something higher like 130, or disabled? I know the speed warning makes quite a distinct dong rather than relay click in the MKVI, but maybe your donger is broken haha, sounds rude.
    May 2011
    Melbourne, Vic
    Hi Tonymy01.
    As far as I'm concerned I don't have a speed warning... It is an early MKIV 2000 model to be precise so it doesn't have any fancy display like the later models did...
    Thanks,
    bruce93
    Jul 2011
    Ticking could caused by many things. Is the noise always there as you described?? If not possibly tyre has picked up something? Possibly could be the purge valve activating but this can also heard at idle. It's located in front of the water reservoir on top of the charcoal canister. You could also possibly have loose wheel arch trim when at speed cause ticking? Hope some of these ideas help.
