And my steerings off a bit and has a shuddering coming from the front wheels, tried wiggling the tie rod ends but no movement, brakes could probably do with replacing but it doesn't seem like warped disks, tried wiggling the drive shafts and there's a bit of movement. Could that mean damaged or worn shafts or is there supposed to be a little bit of play? They seem to make a whizzing noise every now and then. Also the engine is a bit sluggish, I've used some fuel system cleaner and injector cleaner which got me thinking could it be not enough oil pressure along with the fuel/air? I put some stop smoke in yesterday(all I could find in my area without driving and damaging the car further) to try thicken the oil a little bit and see if that helps but no change
no luck with this car
