Results 1 to 10 of 13
Thread: Golf IV Electrics Knocked Out by LED Brake Light Bulb
    Dec 2007
    Hi Fellow Watercoolers,
    I fitted LED brake light replacement bulb to my MK4 Gold Sport and it has caused the following to stop working:
    1. Remote Lock/Unlock
    2. Electric windows
    3. Sunroof
    4. Lights on Chime
    I checked the fuses, they seem intact... so I started to get worried.
    I will disconnect the battery to see if that sorts it out... failing that I may have had an ECU fail.
    If anyone has had a similar issue, I'd appreciate any ideas or feedback.
    Thank you
    *** It's Only a Car ***
    Apr 2008
    Did putting the stock bulbs in place fix the problem?
    It's extremely unlikely that LED bulbs killed your ECU, though confusing it is a definite possibility. Make sure that the LED bulbs you've used have the correct resistors across them so that the bulb "looks" like a standard bulb to the car. Otherwise you'll face exactly these sorts of issues.
    Nothing to see here...
    Jul 2007
    Brissy
    ^^ What he said.
    Undo your last step to begin trouble shooting.
    Check the fuses with a multimeter or test light. Don't just rely on a visual.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Dec 2007
    I put back the stock bulbs and the said electrics are still out.
    Quote Originally Posted by Manaz View Post
    Dec 2007
    Thanks for the tip, I'll check them non-visually as well.
    Quote Originally Posted by JustCruisn View Post
    ^^ What he said.
    Jul 2009
    Geelong, Victoria
    check the wiring in the holder too, make sure nothing got shorted out when you replaced the bulb
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
    Dec 2007
    Looks like the comfort module Karked it. I will do further investigation to confirm. I hope a Comfort module is not too expensive to replace.
    Quote Originally Posted by Stan View Post
    Jun 2012
    Hey, could you take some photo's of access to your comfort control module if possible? I'm really short on spare time to go digging around for mine and I think it needs replacing or at least checking (I've got all sorts of electrical issues). Thanks!!!
    Jul 2009
    Geelong, Victoria
    CCM from about 450 and up on ebay. Make sure you get the right part number, and some have two plugs and some have one so be careful.
    givemecoffee- see if you can scan your car, might help
    Dec 2007
    I'm dropping off the car to a mechanic to fix... I diagnosed it with the help of my brother in law, I'm a hopeless mechanic.
    Quote Originally Posted by Givemecoffee View Post
