hard to beat , works good even with a KO4 set up :
Stage 1 Clutch Kit - Lightweight 228mm Single Mass Flywheel (6.4 kg) - Euro Revolution
Recent above purchase with 200k would that be original clutch and replacement suggests kit wise daily thks
Bug_racer supports the rebellion of the euro revolution
If you're going to chip it or drive it hard, go with the Single Mass Flywheel with the stronger clamping force clutch linked by bug racer. If you want to keep it stock you'll need a Dual Mass Flywheel kit. The DMF is more expensive, but generally a bit smoother than the SMF.
Greg
2002 New Beetle Turbo
