Results 1 to 4 of 4
Thread: Golf door removal.
    Jun 2011
    Golf door removal.
    I have a door which I would like to replace (too many knuckle dents to fix up). I do have a spare door but I am a little stuck as to the best way to remove / replace it.
    Where do I get the star keys that would undo the door bolts with.
    Or is there a pin I can push out to release the door ? (similar to Astra, Commodore etc doors)
    thanks in advance.
    Aug 2011
    melbourne
    VWVortex.com - DIY - Door pin removal for MK4 J/G
    should help. keep in mind, youll want to pull the electrics out first so you dont destroy your door loom, so youll need to probably take the door card off first, which youll do anyway to keep your interior same same, im guessing.
    see here - VWVortex.com - DIY - Removing front door parts (door panel, door unlock handle and sideview mirror)
    '02 GTI (clicky) - REFLEX SILVER - VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
    Mar 2010
    Lesmurdie
    Ah that's not what you think it is Leigh, That's the locking pins on top of the door.
    Quote Originally Posted by leighaus View Post
    Try this thread.
    HELP!! Removing Door on MK4 Golf - Club GTI
    Would just seem undo wiring loom, Undo all the bolts on the two hinges and it should come off.
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Aug 2011
    melbourne
    ah, i didnt really have much of a read to be honest. cheers
