Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Golf Central Locking problem
    Aug 2007
    I suggest wiring it up seperate from the Vw plug mate. Beware using a Laptop on it as well as this can get damaged when wired to the original VW plug. Get yourself a new 12v supply, Ign supply from elsewhere and you will be laughing mate. The drama all lies in the original plug. Your central locking is fused on the same line as the Radio. With the seperate wiring then introduce your own inline fuse. Central locking will then be spot on with the Alpine mate
    Jmac
    Alba European
    Mar 2009
    Update :
    Everything's fixed and I'm a happy camper again!!
    Found a great guide for installation of aftermarket stereos here :
    http://uk-mkivs.net/forums/t/177496.aspx
    The Autobarn installer had botched a few of the wiring positions in the harness. Once these were put right, the stereo worked fine and the keyless entry did too.
    Just saved myself a whole lot of dough by not having to take it to the dealer to be checked out.
    Thanks to everyone for the advice. This is by far the friendliest forum I've ever come across!!
    Feb 2008
    Auckland NZ
    bugger i only just found this post, yeah i was going to say you have wiring crossed over and most likely have the K-line connected by accident.
    Another guy on this forum had his radio installed funnily i think it too was Autobahn.
    Well it ended up blowing his ECU so he had to replace it. Ouch
    Audi S4 (2001) - Imola Yellow
    Secret Project
    Jun 2008
    South Coast N.S.W.
    New list of things not to do today
    1. Do not have new head unit installed by Autobarn
    Russ
    Russ
    2005 Subaru Outback 3.0 R Premium
    Aug 2007
    Just a quick one on that, if the k line is wired wrong you can zap your laptop when scanning too, NOT good.
    Jmac
    Alba European
    Mar 2009
    Quote Originally Posted by Jmac View Post
    Jmac
    It's all good, I made triple sure the K-Line wasn't connected to anything in the harness.
    Mar 2009
    Quote Originally Posted by Russ59 View Post
    Russ
    Amen to that!!
    Aug 2007
    Yeah they have no idea, the alpine isnt diagnosable so why have a K line
    Good its fixed
    Jmac
    Alba European
    hey guys i was the original poster here haha i finally got it plugged in to a compuer at my mechanic and the message coming up was driver door module no communication (may be because i took the door and plugs off at that stage) and it also said WINDOW REGULATOR FRONT RIGHT DRIVER SWITCH IMPLAUSABLE SIGNAL.
    anyone know whats goin on any help wuld be much appreciated needs to be fixed
    Aug 2007
    You need to check your measured value blocks for the doors which can be done seperately. This will tell you what state the micro switches are in open or close. I would be saying your door panel is coming back off, no comms, something off, implausable could well be the module is faulty.
    Jmac
    Alba European
