Results 1 to 9 of 9
Thread: GOLF 99-04 mk4 SUPERWHITE globes xenon
    OMGMK4 Guest
    Hi All,
    Sort of addictive all this stuff!
    These arrived in today's mail from a fleabay purchase I made,
    How hard are the to fit?
    Anyone got any tips that I may need when I get a minute to pop them in?
    Any frustrating bits that i may be faced with?
    Im sort of thinking I will need to take the battery out to ge to the o/s headlight, am I right?
    Is it worth bothering with?
    Thanks.
    Mar 2007
    Quote Originally Posted by OMGMK4 View Post
    Hi All,
    Thanks.
    One thing you must NEVER do with these ... it touch the glass surface of them with your bare hands ... the oil in your skin will ruin them and cause them to fail very shortly thereafter.
    Dave
    Apr 2006
    Hi All,
    Thanks.
    lol they are not Xenon... they are just normal H7 Bulbs, with a Blue Contact Foam around them.
    OMGMK4 Guest
    Checked the fine bule print on the pack, says on both the H7 & H3's that they are Xenon & H.I.D Look globes. Cant hurt giving it a go.
    Jan 2008
    Quote Originally Posted by DaveMack View Post
    Dave
    Should make them explode, coz the oil heats up
    Aug 2006
    these r jst normal globes wif the blue tint.. u cant see **** at night coz its blue
    Hi All,
    Thanks.
    i replaced mine last week with the phillips blue vision, and they are an absolute skank to fit, easiest way to replace them (although most time consuming) is to remove the front bumper and then the headlights...
    i managed to change mine without removing the bumper, but as you mentioned the battery will have to be removed
    the H3's are easier as you can see what youre doing and the clip that holds them in is easy enough to do back up
    my main problem was with the H7's, the clip that holds them in sort of has to be pushed in and slid to the left (if youre facing the car) and i find you have to do this without being able to see what youre doing as the position doesnt let you see properly
    i found the easiest way to see what was going on was to stick my digicam in there and take a pic of the setup so i could get my head around it all, once i did this i had it all back together in no time
    have fun
    edit: oh and with your H7's you should get some parkers too, there reletively easy to fit - i just used some long nose pliers/fingers to jiggle the holder a bit and it came out
    1999 MK4 GTi 1.8T - Custom Code Stg 1, ECS Stg 1, 14lb Fly, 18" A8's
    ''Jap cars pull the G-Forces... Euro cars pull the G-Strings...''
    Quote Originally Posted by 1DUB2C View Post
    ive got the blue visions, they look blue in the pack but once there on, there very white and dont look blue at all
    oh and there legal - anything above 4000k is illegal due to the spectrum that they omit not being reflective dispite them 'looking' brighter or something like that
    the cheaper 'blue' globes are gay as like you mentioned there purely cosmetic and dont do much in terms of vision at night
    Mar 2008
    Perth WA
    Quote Originally Posted by HOLEIN1 View Post
    have fun
    What did you think of the phillips, are they better than standard. How much better?
